why is my srs light flashing
Old Jun 8, 2005 | 01:48 PM
dizzybonez's Avatar
400 E
I have a intermittant srs light indicator, what is the cause of this?
Old Jun 8, 2005 | 02:23 PM
Bigdot's Avatar
some
the older MBZ after 10 or so years need there airbags replaced,
look on the driver door where the VIN is, there should be a sticker indeicating when your airbags SRS need replacement!
i think this is it!
MArk
Old Jun 8, 2005 | 03:45 PM
dizzybonez's Avatar
400 E
Thumbs down oh no
thats gonna be a expensive one heheheh
Old Jun 8, 2005 | 04:01 PM
YNVDIZW124's Avatar
lots of cars
Go on ebay see if you can find one cheap.
Old Jun 8, 2005 | 07:04 PM
Bigdot's Avatar
some
yeah try Ebay, but double check my guesses so you dont spend a fortune on nothing!
makr
Old Jun 8, 2005 | 08:44 PM
Kestas's Avatar
95 E320 Cabriolet, 108K
Are you guys sure about this? It doesn't make sense. How would the car know the bags need replacing and start flashing a light?
I suspect there is tarnish or corrosion on the connectorsd, or a break somewhere in the circuit. This trips off the light to alert the driver that the bag may not go off when needed.
Old Jun 8, 2005 | 10:30 PM
ashman's Avatar
2004 C240, 2015 GL350 Bluetec
could be a worn contact ring on the back side of the steering wheel as kestas suggested.
AshMan
Old Jun 12, 2005 | 08:02 AM
RunInColorado's Avatar
2007 CLK350 Sport, 2006 E320 CDI, 1978 Cessna 152
My mother drives a 89 300TE and father a 86 190D. Both have the original airbags in them. There has been some debate within the family whether or not the bags even need to be replaced as per MBs suggestion. The Dealer wanted 4-7k to replace them. The SRS light does not flash in either car. Have other members had their SRS light flash when the bags are needed to be replaced?
Old Jun 24, 2005 | 07:28 AM
endrema's Avatar
I had the same problem and the problem was solved "by accident" when cleaning the car inside. Below the driver seat I found two connectors that had been pulled almost apart. Probably beacuse they get mixed up in the seat adjusment mechansim. I put them together and the SRS went off and my seat heating also came back. maybe there is connection to the safety belt system or something from the SRS system. I don't know.
Old Jun 24, 2005 | 08:15 PM
Bigdot's Avatar
some
on the door panel by the vin and car info. there should be a sticker indicateing the date to replace the bags.
MArk
Old Jun 24, 2005 | 08:30 PM
CDP's Avatar
CDP
W124's
Hmm...my car said it needs to be replaced in 2005...wait...it's 2005 already huh! haha
