2000 E55 wheels/tires on a '93 300TE?
Collections Ban
Lorinser
Tires will definately be too tall. I think the wheels are the AMG Styling II's in 8.0x18 ET31 & 9.0x18 ET35... super aggresive on a W124... If the wheels are staggered, they will not work. If it is 8.0x18 ET31 all around, you can run them on your W124 with 225/40R18 but some serious fender rolling is a definate must. Here are the AMG wheels that will fit the W124's:
AMG 170 400 0102 Styling I 7.5x17 ET37 (225/45R17)
AMG 202 400 0402 Styling II 7.5x17 ET35 (225/45R17)
AMG 129 400 1902 Styling II 8.0x18 ET31 (225/40R18)*
AMG 170 400 0402 Styling III Silver 7.5x17 ET37 (225/45R17)
AMG B6 603 1183 Styling III Sterling Silver 7.5x17 ET37 (225/45R17)
AMG B6 603 1026 Styling IV Silver 7.5x17 ET37 (225/45R17)
AMG B6 603 1302 Styling IV Sterling Silver 7.5x17 ET37 (225/45R17)
AMG B6 603 1030 Styling III (2-piece) 7.5x17 ET37 (225/45R17)
AMG B6 603 1045 Styling III (2-piece) 7.5x18 ET37 (225/40R18)*
*May require fender modification
W124's
Originally Posted by flyt300
as per Luke @ Tire Rack, ET 35 minimum and 215 maximum for a tire on a W124.
on 17's you can run 235's all the way around
on 18's you can run 225 up front and 235 in the rear.
W124's
Originally Posted by cap'n jasper
Err, no, you won't.
Collections Ban
Lorinser
Actually, you're both right. The wheels in question are the AMG Styling II, also known as the Monoblock II. The 8.0x18 ET31 wheels will fit the W124 on all 4 corners using 225/40R18. If the car is lowered, a fender roll is advisable, but it is hard to tell until you fit check the wheels and tires on the car and test the suspension at maximum compression.
Now... if the wheels end up being staggered in 8.0x18 ET31 and 9.0x18 ET35, I doubt the rears will fit a W124 without some serious modifications.
Collections Ban
Lorinser
Originally Posted by AMG_Eric
b4 you buy 1 thing find out the bolt pattern. the new e class has a different bolt pattern.
Since the wheels in question by Paul-HB are from a 2000 E55 W210, they are the AMG Styling II wheels which are 5x112 and are manufactured to use 12x1.5 lug bolts so no prob. It's only if he's dealing with a 8.0x18 & 9.0x18 staggered fitment that he will run into problems.
1992 300CE AMG Hammer Replica, 2004 C240, 2015 ML350
pretty simple. 8" wide is the widest you want ona w124 for wheels unless its a 500e/e500..
offset is key as well. 235's wont work without serious fender rolling and other modifications on a lowered w124 with 28mm offset and 8" wide wheels, because they will rub like mad.
18x8 with an offset of 31 should work fine, tires 225's would probably be best.
W124
Originally Posted by ChrisDPham
Then explain a little bit more than what you've posted. They are just AMG Monoblock wheels.
The simple answer is no, they won't. The rears on the E55 are 9x18 which is too big. Also the tyres are the wrong size.
very very old post... (just ran across this through a random search) Just FYI: I had looked at the offset on the rim off my 300TE 4MATIC and it's stamped 45 with 6.5 width (stock tire size 195/65 IIRC)
1990 300E
225/40/18 with ET 35 rubbed on my 300E (lowered) - both front and rears.
Had to switch to 215/40/18, and rubbing stopped.
https://mbworld.org/forums/e-class-w...lp-please.html
