Coolant Problems?
Old Jan 3, 2006 | 06:40 PM
FiFth_StreetZ's Avatar
2008 E92 M3
Coolant Problems?
Recently i suspect that my 300 is using coolant at a very fast and steady rate. It started last April during long distance trips where the coolant low light came on, i added more coolant and now the coolant is low again. I put about 5-6K miles on it since. Is this common? Does anyone have any similar experiance?
Old Jan 3, 2006 | 07:28 PM
AMG_Eric's Avatar
2016 AMG C63s
water pump leak
water bottle overflow leak
the diversion tube at the firewall
HEAD GASKET
radiator neck crack
old hoses
start with that and see whatcha got.
Old Jan 3, 2006 | 10:24 PM
neanderthal's Avatar
head gasket int he near future
may as well redo the cylinder head while youre there. should be abuot $1500 or so.
Old Jan 3, 2006 | 11:10 PM
2008 E92 M3
daaamn, how long do u guys usually need to refill your coolant? I guess ill have it checked out...
Old Jan 4, 2006 | 01:06 AM
AMG_Eric's Avatar
2016 AMG C63s
never
Old Jan 4, 2006 | 01:33 AM
e320newbie's Avatar
91' 300e // 99 300e TD // 00' ML55 AMG
i ****ing hate coolent problems! good luck homie!
Old Jan 4, 2006 | 01:59 AM
X03's Avatar
X03
MB 1990 300E
oh good im glad somebody already made a coolant problem thread because i've had some problems recently. alright so a couple of days ago the low coolant level light went on, so i refilled it, and didn't think too much of it. but today after running a few errands and comming back to my car about 2 hours later, the inside of my winshield was foggy. just the winshield, no other windows. my friend told me it was the heater core leaking the coolant. any ideas on this?
Old Jan 4, 2006 | 02:17 AM
it could be
it could aslo just eb condensation on your windscreen.
watch your coolant level.
Old Jan 4, 2006 | 04:13 AM
cap'n jasper's Avatar
W124
AMG Eric has highlighted all the common places. If you still can't see the leak take it to a garage that can pressure test the system.
Old Jan 4, 2006 | 09:01 AM
Z300E's Avatar
1993 300E 2.8
If fog on the inside of your windshield is oily, figure on it being the heater core.
Old Jan 4, 2006 | 07:52 PM
X03's Avatar
X03
MB 1990 300E
hmm thanks for the info, im pretty sure that all the stuff amg_eric listed has already been replaced so ill have to check the heater core again since it couldn't have been regular condensation, like z300e said it was somewhat oily.
Old Jan 4, 2006 | 08:20 PM
AMG_Eric's Avatar
2016 AMG C63s
if your heater core is leaking you will have WET carpets. the heater core is on the passenger side of the firewall.
cap'n jasper has the BEST advice. have it pressure tested. when its pressure tested it pukes where it leaks. if it is a head gasket your car will run like **** because 1 cyl will be full of water.
