Starting Issues
Every morning I...
1. Turn the key and and leave it turned all the way
2. Pump the gas while the its turned all the way
3. Once I finally get it started I have to rev it around 2K RPMs and let it warm up enough to release the gas pedal...at this point it will no longer sputter and shut off!
Every morning I feel guilty of doing this to my baby but since she turns on then
oh yea it all started after I replaced my alternator and battery
you will see a relay clear plastic top remove fuse and check it 10 amp
there is a list of things to do when installing a battery besides just yanking it out goes the same for jumping it this relay is very touchy
as far as EHA/FUEL GOVERNOR IF NOT LEAKING DONT MESS WITH IT
IF IT IS JUST REPLACE ORINGS IF LEAK IS AT SEAM IF LEAK IS AT SMALL
HOLES IN BACK THEN YOUR SOL AND MUST REPLACE I GOT MINE USED
AT SALVAGE FOR 65 IT WAS CRAP BOUGHT ONE OFF ENTERNET FOR 150
FOR HIGH FLOW UNIT MORE PONIES NO MORE PROBLEM GOOD LUCK
Well the harness to my alternator looks like *****...I've always figured that to be the culprit...
