another Oxygen Sensor Question e320 1994
Old Mar 4, 2006 | 05:30 PM
ML55CLA45's Avatar
2001 c320 - 2002 ml55 - 2011 c300 - 2014 slk350 - 2015 cla45
https://mbworld.org/forums/showthrea...ight=oxygen+se
hey guys.. need some help.... i was planning to follow the above link in order t change my oxygen sensor but when taking mine apart ive noticed that the o2 sensor on my car has 4 wires... 1 black, 2 white, and a gray.....
from the above link the O2 sensor only had the black and 2 whites......
so im guessing that the sensor changed for the 94, 95 e320.... anyways.. i will post some of the pictures...
i purchased the bosch o2 sensor in the link pn 13953... but again. it has three wires and the sensor on my car has 4.....
anyone have any idea has to what i should do... will this one work?,, or is there another bosch sensor that i should have purchased instead of this one?
any help would be greatly appreciated!!
charles
Charles@carino.com
Old Mar 4, 2006 | 05:35 PM
YNVDIZW124's Avatar
lots of cars
I think the one you need comes off a chrysler van but im not sure....search for 4 wire oxygen sensor on benzworld or here?
Old Mar 4, 2006 | 06:03 PM
ML55CLA45's Avatar
thanks, i found it...
bosch part number 13314 $140ish
bosch part number 13275 40ish... this is the one you have to splice in
-carino
Old Mar 4, 2006 | 06:09 PM
YNVDIZW124's Avatar
lots of cars
im talking about the cheaper universal one...since we use the ones from a 90 mustang that cost $45 not $120
Old Mar 4, 2006 | 06:13 PM
ML55CLA45's Avatar
thanks... YNVDIZW124
yeah i called the local auto store and they said the 13314 was 140ish.... so i figured that was the one you will not have to splice in... im giong to go buy the 40ish dollar one.. and then use the $100 for going out tonight.. hahah
thanks again
-carino
Old Mar 4, 2006 | 11:17 PM
Kestas's Avatar
95 E320 Cabriolet, 108K
I don't think the $40 Chrysler or Mustang O2 sensor will work in the 94,95 E320. I think all the archived information is for earlier models. The E320 model requires a different sensor. You definitely need a 4-wire sensor. I don't know which spliceable $40 sensor will work in this model. The best price I could find was $95 from autohausaz.com.
Old Mar 5, 2006 | 12:43 PM
lkchris's Avatar
'10 CL550, '12 GL550
Four-wire O2 sensors are heated.
Two-wire aren't.
It was a running change and you shouldn't install the older style.
Old Mar 5, 2006 | 09:59 PM
ML55CLA45's Avatar
i used this one.....
i spliced it in yesterday.... i reset the check engine light and drove it around the block a few times and it has yet to come back on..... so far so good...
very easy job to DIY....
