Economy meter at 15% when not moving in D
Old May 25, 2006 | 01:51 PM
MBFreak's Avatar
1987 w124 300E
Question Economy meter at 15% when not moving in D
Hey,
Just recently i noticed that when i'm stopped for a red or so, and in drive, the economy meter is at about 15-20%, where in the past it would allways be resting at the 0% pin. On top of that i've noticed a rather sharp mechanical noise from the back. The thing is that it's not constant, it's rather vague usual- but sometimes its rather loud.
The economy meter is at 0% when in park or N.
I've just recently had 18" rims mounted on it, which is actually a bit too large. Could this have caused some kind of extra wear or damage around the drivetrain/dif.?
I know this could probably mean a hundred things, but i hope someone might have some advise to where to look?
Thanks in advance,
BR
Old May 26, 2006 | 02:29 AM
X03's Avatar
X03
MB 1990 300E
mine does the same thing. i believe its a vacuum leak somewhere, i have no idea where to look though. i doubt your wheels have anything to do with the economy gauge.
Old May 26, 2006 | 02:51 AM
CDP's Avatar
CDP
W124's
did you ever fix your fender?
anyways, mine was reading weird at first for a little bit as well, but I changed the O2 sensor and it started reading more accurately. Don't know if the 02 has anything to do with it though.
Old May 26, 2006 | 10:28 AM
shadowgriffen's Avatar
is a German Tank
My reader does the same thing, its always at about 15% while at Red lights and such, but when on park its at 0%. I avarage around 18-20 MPGs while in the city so I've never bothered to do anything about it...I actually thought it was normal
Old May 26, 2006 | 01:54 PM
crr1612's Avatar
Mercedes benz 1991 300ce(RIP), now an 89 300ce
same thing with me, i dont think its a problem. but as soon as i take my foot off the gas, my rpms go up a tiny bit and the economy meter moves to full. maybe it has somethign to do with your power brakes using up engine power....idk. but your problem seems to be pretty normal
Old May 26, 2006 | 02:15 PM
MBFreak's Avatar
1987 w124 300E
Hey! -Thanks for all the answers.
It's good to hear that my "problem" isn't unusual
Anyhow- just weird that it came just after i got the car back from service, and when the mechanical noise appeared. i've persuaded my mechanic to perform a compression test for free the next time i visit, but it only seems fair as he's sucked my dry already..
Naw my fender is still busted- it really sucks- but I'm looking into new spring pads- as those Vogtland springs aparently costs 300$. I just now lifted the car and tried to feel the spring pads, to determine how large they are. My guess is that they're at least 15mm high, couldn't feel any dots or marks that should indicate their size- anyone know if this could be a size 4? (the largest) -(isn't 4 like 18mm?)
BR
Old May 26, 2006 | 03:48 PM
ashman's Avatar
2004 C240, 2015 GL350 Bluetec
there should be some little nubs on the spring pads
Old May 27, 2006 | 11:34 AM
MBFreak's Avatar
1987 w124 300E
yea, i just looked and i have 3's on- so not a huge difference upgrading to 4's.. I might as well just get new springs, which i was told MB makes in 1 to 5 sizes or so as well, and the just ajust it with pads afterwards..
/J
