Automatic door locks wont work!!
Old May 26, 2006 | 11:38 AM
hellah fresh's Avatar
Was 89' 300E, Now 93' 500SEL
Ok this has been a prblem for some time now. Before all 4 door locks work whenever i press down on the driverside lock. Now it doesnt work. Anyone know what seems to be the problem here? I hear the rear passenger motor whenever i lock it but i hate to have to manual lock all the doors. Anyone know??
Old May 26, 2006 | 11:46 AM
ashman's Avatar
2004 C240, 2015 GL350 Bluetec
the locks work by vacuum. have you checked the vacuum motor? perhaps it is a vacuum line. or it could be the vacuum pump.
Old May 27, 2006 | 02:22 AM
Do you know where i can find the vacuum line? I think you might be right. I changed out the fuses and still wont work. So yeah im guessing its the vacuum line. Do you think it might be clogged up or something? Because when i push down all for locks manually i can hear the rear passenger side motor. Sounds like something is activated when i lock it but nothing happends. So basically it stays on untill i unlock it. =\
Old May 27, 2006 | 06:52 AM
PaulX608's Avatar
2011 VW cc, 2004 ML350
There are buttload of vacuum lines in these things. The pump is under the passenger side of the rear seat. It will run until everything it's supposed to close or latch are done. I had a similar problem after my recent stereo installation at a local audio store. Traced the problem to a loose vacuum line in the trunk that goes to the gas door lock. Seems the stereo installer draped this line up over the trunk hinge spring to keep it out of his way and inadvertantly pulled it loose from the gas door lock. It was easy to fix, just put it back on. What you'll have to do is pull out the rear seat bottom to expose the pump and lines, and possibly open the trunk and pull out the passenger side trunk lining. Then get a couple friends to stand around various parts of the car listening for a vacuum leak while the pump continues to run. You'll find it. Good luck.
Old May 29, 2006 | 09:52 AM
ebennz's Avatar
it sounds like one of the vacuum lines in the drivers door is off or cracked.
your problrm is MOST likely a loose or cracked vaccum line there.
this is not uncommon nor is it a major fix. replace the line.
Old May 31, 2006 | 12:42 PM
im guessing what your guessing too! Im thinking its a line that broke/cracked. Is there a main line that is causing all 4 doors not to lock automatically?? I checked it out today and whenever i press down on the front passenger door lock i can hear the vacuum pump working in the rear passenger side seat. So i know my vacuum is working. Im thinking its 1 maine line but not for sure which one. Where do i start?
Old May 31, 2006 | 04:39 PM
ashman's Avatar
where you start is at the pump I guess. pull all the lines off and plug the tubes on the pump and the lines. then plug one in and test. I would assume. or you may need a vacuum tester and test each line.
Old May 31, 2006 | 11:31 PM
Where do i get for find a vacuum tester? I see there are like 2 lines on each side of the rear seats. Do i need to go through the carpet to get to all the lines?
Old Jun 1, 2006 | 10:04 AM
mhorn's Avatar
1991 300E
this should help
http://mb.braingears.com/124_DISC2/P...sis/80-010.pdf
this will show you where all the vacum lines are if you don't know already.
Old Jun 2, 2006 | 04:45 PM
Man... i dont even know where to go with that layout. Should i just buy all new lines? I think that should atleast help out a bit huh..?
Old Jun 3, 2006 | 02:19 AM
ashman's Avatar
Just check the lines that are coming off the pump, each of those goes to a door / lock. if one of them wont pressure test, you will know which one and will be able to trace it.
Alon
Old Jun 3, 2006 | 03:10 PM
Adso's Avatar
320CE Sportline '92 - C270 CDI '01 - VW Golf III GTI 8v
superb information! This is what I was looking for to install the locking-door switch! I will open another thread about that...
Old Jun 4, 2006 | 06:40 PM
Alon
The pump is the one that is located in the rear passenger side right?
Old Jun 5, 2006 | 06:19 PM
^bump^
You guys think when i get my aftermarket alarm system installed they can find the problem?
