18" = bashed fender
Old Jun 4, 2006 | 11:11 AM
MBFreak's Avatar
1987 w124 300E
Angry 18" = bashed fender
Hey!
When i got this car, it was dropped with original 15" rims. I don't know excactly how much it was dropped, but i'm guessing 40-45mm (1,7inch).
I am running 18/225/40 on the front.
Anyhow, as the picture shows, it's too low for these rims!
The spring pads are a size 3, so upgrading those to a size 4 won't solve the problem i guess.
There's no rubbing when driving normally, but when turning on a non levelled road it grabs the lip, and it's hitting the fender when turning normally on a bumpy road.
I was told by my dealer that you can get original springs that comes in sizes 1-5 or so, at under 70$ a piece.
2x vogtland springs will cost me 300$, which might cause the same problem? most of the dealers i've asked just tells me that the rims are too large, bahh!
Anyhow,.. anyone running same specs? and can give me a hint on what size springs to get? -would be nice to have the problem solved before replacing/fixing the fender!
BR
Old Jun 4, 2006 | 04:14 PM
GORBETTTEAM's Avatar
'95 3.2 M104
that's pretty much the worst fender rollin' job i've ever seen......
you don't need no wheels, you need to get your fenders fixed.
- gorb -
Old Jun 4, 2006 | 05:33 PM
YNVDIZW124's Avatar
lots of cars
I don't know who you talked to but you need to get a rubber mallet and cover the edge of the fender with tape, I would use blue 3m masking tape and roll the fender in by hitting the edge until it's nice and smooth. I'm running 18x8 35 offset rims and i don't rub at all with 225/40/18. Firt you have carlsson wheels and im sure their 18x8.5 so that's you first problem since they mostly come in a 35mm offset. That .5 and with the fenders not rolled makes them rub.
This all means that you need to properly roll the fenders or get someone that knows how to do it. I'm also running eibach springs so it's not that low. You can get a spacer kit for the fenders to get the tire to tuck under those fenders.
ohhh the best tires i suggest you get for 18s or 19s are falken tires. They have a reinforced side wall and have this big rubber lip around them that saved 2 of my rims. 1 from a big pothole i hit and another from curb rash. If it wasn't for the tires i would have needed to replace my rims by now.
Old Jun 4, 2006 | 05:40 PM
Makahveli's Avatar
"88 300CE- First Year Production
Keep the rims, how are the rears?
Old Jun 4, 2006 | 05:46 PM
SFoRZA's Avatar
C32 AMG 2002
ummm thats more like an unrolled fendor
Old Jun 4, 2006 | 06:21 PM
neanderthal's Avatar
id stop assuming i know more than my mechanic.
Old Jun 4, 2006 | 06:37 PM
Makahveli's Avatar
wow, mine drop is said to be 45mm, in my opinion you need fender spacers or a less-wider rim.
Old Jun 4, 2006 | 08:29 PM
X03's Avatar
X03
MB 1990 300E
before doing anything, put your stock wheels back on. thats horrible, too hard to look at.
Old Jun 4, 2006 | 09:02 PM
CDP's Avatar
CDP
W124's
Yup, I'm running Falken Azenis and they pretty much saved my wheel yesterday when I thought I curbed them really bad. It's known as the "Sidewall and shoulder reinforcements"
Old Jun 4, 2006 | 10:21 PM
Bigpete123's Avatar
1990 300ce
I definitely agree that the problem is not the fact that you have 18 inch wheels. I have 18x8's ET35 with 225/40/18's. My car is lowered a little more than YNVDIZW124's with H&R springs. No rubbing whatsoever.
So the problem is either one of these things or it's a combination of them:
1) Your fenders have not been rolled (i.e. the inner lip of the fender hasn't been bent in as YNVDIZW124 describes)
2) Your wheels are too wide
3) The offset if your wheels is too agressive. With 18's, you almost for sure need 18x8 with an offset of ET35 and 225/40/18's. This is the only 18" setup I have seen consistently work without rubbing on w124's.
4) You may need fender spacers, but I'd roll the fenders first. If you like your rims and they are too wide or have the wrong offset and they still rub after you roll the fenders, then get the spacers.
Sorry you had this problem, man. That really sucks!!
Old Jun 4, 2006 | 11:27 PM
YNVDIZW124's Avatar
lots of cars
Remember to put tape on the edge of the fender when you roll them because the paint will crack and chip off. Do not use anykind of pliers. You can work the fenders with a soft rubber mallet. After you bend it back make sure to get something behind what your hitting because other than that the mallet will just bounce off the fender and not roll them.
Old Jun 5, 2006 | 12:28 AM
SDR's Avatar
SDR
'99 C43, '12 C63, '13 E350, '14 Sprinter
Looks like an offset problem to me. I'm not an expert, but I play one on the forums
Old Jun 5, 2006 | 01:47 AM
Bigpete123's Avatar
1990 300ce
Agreed. Also, make sure that a heat gun is used. I had a shop roll my fenders and they absolutely destroyed the paint. Basically they did not acknowledge that they messed it up. So I had to sand, prime, paint, and clearcoat the inside of the wheels myself. So make sure they use a rubber mallet and a heat gun.
Old Jun 6, 2006 | 09:07 AM
CLJ's Avatar
CLJ
300E
Yep I did the same thing with mine though not quite as bad. Just remember the car was not designed for those size wheels so extra care should be taken on sharp turns over bumps. And definitely do as others have suggested and bend the fenders up, it should stop it happening again.
Nice wheels by the way!
