Calling Chrisdpham!
#2753
Dora the Explorer
Oh yeah, didn't think about that.
So what good does it do to make the front wider if you can't make the back wider. I assume it does some good or they wouldn't sell them, I just don't get it.
#2756
is a German Tank
#2759
is a German Tank
#2761
is a German Tank
#2762
W124's
I was going to but TWS said I didn't need them and it turns out they were right. I'll probably put those on my E420 though when I lower it. It helps with the shock when it rebounds to the strut mounts so if you're running aggressive wheels and driving aggressively you wont have to worry about the rubbing so much.
#2766
W124's
#2767
89 300TE, and 68 280sel
not to take away sales from the phamly... but why not just go out to the local hardware store and buy some rubber washers and stainless washers as well as longer bolts. I did this on my 400E. I used these on the front of the fender below the corner light as well as the two bolts at the bottom of the fender towards the doors, right behind the wheel. Worked like a charm, I found that a combo of rubber washers and metal washers work, but you might as well just buy a hand full of metal washers and space them that way.
