Calling Chrisdpham!
Rating: Thread Rating: 6 votes, 5.00 average.
Old Aug 11, 2006 | 07:20 PM
  #551
mgw_300e's Avatar
Dora the Explorer
Originally Posted by ChrisDPham
Yeah, Mercedes Shop has a tutorial on their website. I followed that and can't get it out. I might just buy the "special" tool to remove it.
OK, I'm a freaking idiot. It just occurred to me that you said mercedes shop and that's what I just gave you a link to.
Somehow it registered in my head that you check MB's web site. That of course makes no sense now that I'm thinking it through.
Old Aug 11, 2006 | 07:28 PM
  #552
CDP's Avatar
CDP
W124's
Originally Posted by GORBETTTEAM
Hey,
That guy " speedy300Dturbo " was just recently sellin' his old A/C control unit on eBay and I asked him "why" would he replace a perfectly working unit. Guess what....he never wrote me back. My guess you never know what you can get. BTW. Looks like he's everywhere(here's eBay link).
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
I ordered a few OEM parts from him and they were pretty good. So I don't have a problem buying anything from him again in the future.
Matt - I tried that tutorial ... I guess I'm not trying hard enough to remove it. lol
Old Aug 11, 2006 | 07:42 PM
  #553
mgw_300e's Avatar
Dora the Explorer
Just put one foot on the dash on each side of the steering wheel and pull till it pops!
Old Aug 11, 2006 | 07:45 PM
  #554
CDP's Avatar
CDP
W124's
what did YOU say? LOL
Old Aug 11, 2006 | 07:52 PM
  #555
mgw_300e's Avatar
Dora the Explorer
DISCLAIMER: I take no resposibility for any consequences that result from following the advice given in my last post. As with all car repair, sound judgement is the key. Using both feet to do any modifications of your Mercedes Benz vehicle may result in serious injury, dismemberment, death, or at least loss of self-esteem, so: look before you leap, measure twice cut once, an ounce of prevention is worth a pound of cure, and don't forget to bring a towel.
Old Aug 11, 2006 | 08:02 PM
  #556
GORBETTTEAM's Avatar
'95 3.2 M104
LOL
Old Aug 11, 2006 | 08:16 PM
  #557
mgw_300e's Avatar
Dora the Explorer
I was just picturing Chris all sweaty with half his dashboard in his lap, bent coat hangers in each hand, knuckles bleeding, mad, and yelling "well why the hell didn't he type 'LOL' after posting joke advice!!!!!"
Last edited by mgw_300e; Aug 11, 2006 at 08:18 PM. Reason: i thought up more funny sh!t
Old Aug 12, 2006 | 12:20 AM
  #558
CDP's Avatar
CDP
W124's
"Last edited by mgw_300e : Today at 05:18 PM. Reason: i thought up more funny *****"
lol you f*cker.
Old Aug 12, 2006 | 12:53 AM
  #559
Saijin_Naib's Avatar
1990 300ce 24v I6
heey now children... lets all just get along mmm? Oh my dad said not to **** with the dashboard because you can set off the airbags and potentially kill yourself.
Old Aug 12, 2006 | 05:20 AM
  #560
CDP's Avatar
CDP
W124's
I think my airbags needs to be replaced. lol It's past the due date and sometimes the light goes on. has anyone replaced theirs yet?
Old Aug 12, 2006 | 10:15 AM
  #561
mgw_300e's Avatar
Dora the Explorer
I've heard they should be replaced every ten years or so (or was it 15?). I'm afraid to find out how much that costs.
Old Aug 12, 2006 | 10:17 AM
  #562
mgw_300e's Avatar
Dora the Explorer
lol you f*cker.
Old Aug 12, 2006 | 10:49 AM
  #563
'95 3.2 M104
Your air bag is not the cause of that light that is popping out, Chris. These systems can be reset with the right DAS and multiplexer with right cables. Anyways. Do yourself a favor get your clockspring checked, eventually if the cables/plastic inside are flling-a-part that light you were talking about will lit for you 4ever. Replacement should take about 40-66 minutes depends on the skills.
Removal and Installation :
Remove cover below instrument panel.
Disarm SRS system and remove steering wheel.
Allow steering wheel lock to engage, with front wheels in straight ahead position.
Disconnect connector, contact spiral/airbag (A45x1). Expose cable.
CAUTION : Observe SRS safety precautions!
Disconnect connector, contact spiral/fanfare horn relay (A45x2). Expose cable.
Unscrew fixing screws (32h) sufficiently so that the contact spiral (A45) can be removed. The fixing screws (32h) are also used to prevent rotation.
Carefully remove contact spiral (A45) from jacket tube. Withdraw cables of contact spiral (A45) through the jacket tube trim. When installing, ensure that the contact spiral (A45) is pushed on up to the stop and the recess (arrow) on the contact spiral (A45) aligns with the fixing lug (arrow) on the steering shaft.
NOTE : On vehicles with ADS, the steering angle sensor is clipped to the underside of the contact spiral and can only be replaced when the contact spiral (A45) is removed.
Installation is in the reverse of removal.
Dismantling the Contact Spiral :
The upper and lower sections of the contact spiral are clipped together. This connection is only disconnected due to the effect of excessive force or defective assembly. If this is the case, carefully coil up the contact spiral, compress carefully (do not trap the spiral) and re-assign the center position.
WARNING:
Do not use oils or greases in or on the contact spiral.
The band must not be installed kinked, use a new contact spiral, if necessary .
Center Position of Contact Spiral :
The center position of the contact spiral is decisive for the satisfactory function of the airbag and signalling system. When removed, it is guaranteed by the fixing screws.
If however the contact spiral has been turned, e.g.
when the steering coupling was removed,
by unscrewing the fixing screws completely, the center position is to be determined as follows:
Screw the fixing screws fully into the contact spiral.
Turn contact spiral clockwise until a resistance is detectable.
Turn contact spiral approx. 2 - 2.5 rotations anti-clockwise (turn back) until the fixing screws can be unscrewed again and fix the contact spiral.
Attached Thumbnails Calling Chrisdpham!-78130796.gif   Calling Chrisdpham!-78130811.gif   Calling Chrisdpham!-78130812.gif   Calling Chrisdpham!-78130813.gif   Calling Chrisdpham!-78130814.gif
Old Aug 12, 2006 | 01:12 PM
  #564
mgw_300e's Avatar
Dora the Explorer
Awesome post! This is really turning into a one-thread encyclopedia!
Old Aug 12, 2006 | 03:08 PM
  #565
1990 300ce 24v I6
Yeah, but lets not make it too serious! Okay? It needs to still be fun for work
Old Aug 12, 2006 | 03:39 PM
  #566
mgw_300e's Avatar
Dora the Explorer
Somehow, I don't think we need to worry about that
Old Aug 13, 2006 | 01:38 AM
  #567
'95 3.2 M104
Since this thread droped like 6 or 7 positions, I would like to show you guys something. I'm talking about 6,0 V12 1994 engine for cool $997($1=3zloty)
http://moto.allegro.pl/show_item.php?item=118919538
Old Aug 13, 2006 | 02:54 AM
  #568
'95 3.2 M104
Chris,
What size of those Hammers caps your looking for "exactly".
Old Aug 13, 2006 | 05:18 AM
  #569
CDP's Avatar
CDP
W124's
2.5" is the center cap diameter.
Old Aug 13, 2006 | 10:46 AM
  #570
jdmfiend's Avatar
so i woke up this morning still drunk. wtf.
Old Aug 13, 2006 | 01:09 PM
  #571
1990 300ce 24v I6
Im going to computer show to buy stuff w00t.
Keepin this baby alive!
Old Aug 13, 2006 | 01:33 PM
  #572
'95 3.2 M104
How about these? LOL
http://moto.allegro.pl/show_item.php?item=119337760
Old Aug 13, 2006 | 03:53 PM
  #573
CDP's Avatar
CDP
W124's
dude. I've ben waking up drunk since sunday. tonight won't be anymore different either.
Old Aug 13, 2006 | 03:56 PM
  #574
CDP's Avatar
CDP
W124's
are those the right size? I'm pretty sure it will work and ill just have them painted. find a way to order them
Old Aug 13, 2006 | 08:26 PM
  #575
rooney2006's Avatar
1991 300E
Dude, do you know any reason why clear corners that I just bought don't fit my OEM plugs? The OEM lights had a three socket prong, and the clears had a two socket prong. Any idea what I should do?
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
