7.5Jx16 ET 51 fits W124?
Old Aug 13, 2006 | 06:23 AM
tliang's Avatar
1995 W124 E220 MP 5sp Manual
I am planning to upgrade my oem rim and tire (195/65/15). I found a set of used rims from W140 (7.5Jx16 ET51). Can it fit my W124 with 215/55/16 tires? The biggest ET I found in manual is 46. Is 51 ok?
Thank you for your valuable and quick inputs.
Old Aug 13, 2006 | 10:16 AM
jeffreyli86's Avatar
51 seems to be too little.. the inner side wall of your tires or your rims might rub on the shockers at the front.. don't know about the rears..
heard that the ideal offset is 35 (don't count on me for this, i'm bad at numbers)
hope this helps.
Old Aug 26, 2006 | 05:18 PM
t28mrs's Avatar
89' 230TE
Mb recommends 35 to 38
Old Aug 27, 2006 | 02:40 AM
neanderthal's Avatar
no
the lugnuts are also bigger (wider) in a W140 IIRC
try an R129. thats what im going to do if i cant get AMG aeros
Old Aug 27, 2006 | 04:18 AM
cap'n jasper's Avatar
W124
Since when?
Old Aug 27, 2006 | 12:05 PM
t28mrs's Avatar
89' 230TE
saw this and guessed it must be right?? http://www.alloyguide.co.uk/index.htm
Old Aug 27, 2006 | 01:01 PM
EvoW124's Avatar
W124
i believe this can help you!!
anyway you from SG right!?!
join us!!
Old Aug 28, 2006 | 02:25 AM
W124
Sorry mate but that site is a load of bollocks.
EvoW124, that table is also a bit suspect. 18x10s won't fit most W124s and 35+ is a bit vague?
Old Aug 28, 2006 | 12:46 PM
EvoW124's Avatar
W124
18x10s its only for the Rear... & with wide body...
Old Aug 28, 2006 | 04:44 PM
kwb210's Avatar
1993 300CE Sportline
Et41
I'm running a 16 x 7.5 ET41, the part number is 210 401 04 02 and I believe it is from a newer E320. My car is a 93 300CE w/ Sportline. Tires are 205-55 and there is no rubbing.
kurt
