300E Only Premium Gas?
Any help appreciated.
Thanks!!
There are no knock sensors.
The only way for a 180 cubic inch engine to produce the horsepower the M103 produces is by high compression. High compression requires premium fuel. You risk damaging your engine otherwise (unless you live at 5000 fit ASL or above).
I've had experience with Cadillacs and friends with Caddys and they highly recommend premium for the Northstar v8s but I have never heard a knock in any of them. Could be just me, and could be just a Cadillac thing?
I take it there are no knock sensors for any older model Mercedes either?
me>
<premium gas
SO I moved up to 89. She moved much much better.
Then one day I said ... Stop holding on to your wallet and put in 93
She smoothed out in such a way I had never felt. Everything about her FELT and RAN much better.
Tap the pedal... She was very responsive....
so 93 it is for me......
US figures...
A little (!) smaller than the usual 350 V8 Americans are used to.
Yet, the M103 produces nearly the same horsepower, that is about one horsepower per cubic inch. Unheard of as regards most American engines.
To do that requires a high state of tune which means high compression which means premium gas.
If you want to burn regular, get a Chevy.
