headlight wiper delete plates?
i dont feel like having my body shop shave it and it be in there for a few more weeks. where can i get the delete panel or whatever?
i wanted my headlight wipers at first but i changed my mind.. as usual
Katmac sells them as a $25 extra. Click here then scroll down:
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
The panel itself is held by two screws, one near the radiator/grille and one UNDERNEATH the corner lens.
cool, thanks man. i just wanted to pull off the wipers and then put them back on, but i guess i have to remove everything first. i guess i remove the lights, then the screws for the panel, and it should be obvious how it all comes out after that?
thanks!
4 screws hold your headlights intact.
2 near radiator/grille one upper, one lower (good luck with lower one, it's a pain in the *** to get to. you need a special wrench with a slight curve to get to it (NATURAL shows a picture of said tool, he recommended it to me. It is located in the first couple of pages of "CALLING CHRISDPHAM")
2 near headlight/corner lens frame one upper, one lower
and also each headlight has a tab that holds them in place. You will find these on the very top of the headlights where they meet the frame. these brake quite easy, so its handy to buy some in advance.
good luck.
You will see what I'm talking about, its a b!tch to get to because the air intake mouth is in the way, therefore you could remove it but thats more work and also a b!tch to remove!
sorry I hope not to discourage.
