engine will not turn over
Old Oct 8, 2006 | 12:07 PM
triggerman's Avatar
95 E320 Wagon
Please help guys, suddenly the engine in my car will not even turn over. All accessories and lights work perfectly and battery is fully charged and passes a load test. I get a faint and very short clicking sound coming from the drivers side area, lasts about a second and stops. Sounds similar to what a battery sounds like when its dead and you try to start it, but this clicking is far quieter. I have never had a starting problem at all with this car. It has 189,000 miles. Any help would be much appreciated.
Adam
Old Oct 8, 2006 | 12:22 PM
mgw_300e's Avatar
Dora the Explorer
did you try smacking the starter with something?
Old Oct 8, 2006 | 12:41 PM
triggerman's Avatar
95 E320 Wagon
Thanks for the reply. Actually I just got through doing just that. I smacked and tried it, nothing. Had the wife turn the key while I smacked it, nothing. If the starter is good it "looks" bad now! Also, all the fuses in the box on drivers fenderwell are good. Are there any other fuses or relays that I could look at? If so where are they? BTW, wiring harness is new, OVP relay is new, and various other new engine parts as of a few months ago.
Thanks guys
Adam
Old Oct 8, 2006 | 02:23 PM
JrJammin's Avatar
'91 300E Mercedes Benz
my car was doing something very similar to this... i found no help here on the forums and ended up taking it to the dealership.. it was the EHA Valve and the Air Pump - both needed replaced
Old Oct 9, 2006 | 09:37 AM
shadowgriffen's Avatar
is a German Tank
Adam
DID you try the OVP yet????
I have written a ton of replys regarding this matter, use the search feature it will bring up.
Old Oct 9, 2006 | 11:47 AM
ashman's Avatar
2004 C240, 2015 GL350 Bluetec
Checkt he fuses. there is a fuse that is for the starter and if it is gone it can exhibit this problem. I forget which one it is but I believe it is on the top row. it may look good but it is bad. just check all the fuses by removing each one and seeing if it comes apart in your hands if it does then replace it.
This happened to a friends car once. and it turned out to be a fuse and it had full power on everything full battery and all.
That would eb the first place I would check.
Old Oct 9, 2006 | 12:28 PM
mgw_300e's Avatar
Dora the Explorer
Yes:
Old Oct 9, 2006 | 01:36 PM
is a German Tank
Originally Posted by mgw_300e
Yes:
Sugar pants, I will from now on read every post with EXTREME caution and patience before posting a reply.
PS: I still think you're
Old Oct 9, 2006 | 01:47 PM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
CPS - crank postion sensor ?
Old Oct 9, 2006 | 03:48 PM
mgw_300e's Avatar
Dora the Explorer
You know I'm just busting your ***** <3
Old Oct 9, 2006 | 05:04 PM
Hound's Avatar
1996 C36 AMG, 2013 Dodge Dart Turbo 6spd
mine had a similar issue 2 weeks ago, turned out the car needed a new distributor cap and rotor, also replaced the plugs and fuel filter at the same time as well....
Old Oct 9, 2006 | 10:26 PM
triggerman's Avatar
95 E320 Wagon
I did check each fuse and they all look good and are intact. Also no single fuse is listed as having the starter on its circuit. Loaded it up today and took it to a shop and as I was rolling it off the trailer I thought "be funny if it started up" sure enough it fired right up! But I had them go ahead and pull the starter and am having it rebuilt. Thanks for the help guys.
Old Oct 10, 2006 | 11:59 AM
ashman's Avatar
Did you remove each fuse. sometimes they can get a hairline crack you cannot see until you remove it.
But if the shop discovered it was indeed the starter. then that is good.
Old Oct 11, 2006 | 01:33 PM
triggerman's Avatar
95 E320 Wagon
Had the starter rebuilt and it seems as of now that its fixed! These starters do last about twice as long as alot of domestic ones though dont they. My car has 187,000 miles and it appeared to never have been off the car.
Old Oct 11, 2006 | 01:40 PM
is a German Tank
I recently replaced mine at 227,000 was original.
Old Oct 12, 2006 | 03:21 PM
triggerman's Avatar
95 E320 Wagon
Well my car did it again. All accessories work, battery passes load test, replaced all acc. fuses with new ones, rebuilt starter, and the car as of this morn. will not turn over at all. Right now its just a 2 ton paper weight. Got an appointment with an indie. on mon. Anyone got any new ideas at all I could try before then? I am going to jack it up and check all ground straps etc. that I can find. Could it be ingition switch?
thanks guys
Adam
Old Oct 12, 2006 | 03:30 PM
shahedC's Avatar
OLD: 2004 C230 Sport Sedan, NEW: 2007 SLK350
Never had this problem with a Benz, but I did have it with my 2001 Pontiac Grand Am SE.
It turns out that the pass-lock sensor had failed. That's the device that prevents thieves from hotwiring the car.
The repair shop ended up replacing the ignition lock cylinder housing for less than 500 bucks total.
The car had over 120,000 miles on it at the time.
(I checked the fuses, battery, etc and even the gas tank was almost full)
Old Oct 12, 2006 | 05:06 PM
Lancelot's Avatar
'01 W210 E320 CDI
I've had a similar problem with a 3 y/o van I drive for work. The dealership diagnosed it's ECU, starter motor, ingnition, and battery were all in the green. In the end it did turn out to be the battery; probably bent plates shorting out from time to time. If you can mount another battery from another car you should give it a try...
Old Oct 12, 2006 | 06:04 PM
ZedStyle's Avatar
Youngtimer
i had that problem... what i do now is turn the key to accessory, and let all the lights on the dash light up. wait a few seconds (i usually wait until the airbag light goes off) then crank it anf it starts. it would failt o start every couple of weeks, but since i started doing this, it's been perfect...!
watch it happen again now that i've said it.
Old Oct 12, 2006 | 11:16 PM
triggerman's Avatar
95 E320 Wagon
Thanks, but that didn't work either.
Old Oct 13, 2006 | 06:12 AM
cap'n jasper's Avatar
W124
Check the wiring to the starter. I know you changed the engine harness but the starter is on a separate one.
Old Oct 13, 2006 | 08:04 AM
is a German Tank
LOL Fuel pumps maybe??
Old Oct 13, 2006 | 10:49 AM
mgw_300e's Avatar
Dora the Explorer
That was going to be my next guess, too.
Have someone turn the key to the acc position while you stand by the passenger side rear wheel. If you hear a two second buzz from under the car, your fuel pumps work.
Old Oct 13, 2006 | 01:38 PM
triggerman's Avatar
95 E320 Wagon
Fuel pumps would not apply here since the engine will not even spin over at all. I'm sure if it was a manual I could roll down a hill, pop it in gear and fire right up. I am going to inspect the starter wiring as far as I can find. Thanks guys
Old Oct 13, 2006 | 04:26 PM
ashman's Avatar
if the starter was just replaced, it could be the starter relay.
Do a search on mercedesshop.com and see if others have had this problem. there are some very talented people there who can give you tons of info on what to check.
