Driver's Side seat stuck up high
My question is this, does anyone know how I can fix this myself or with some help? And if so do you have a writeup or link to one??? Thanks, for any and all help as I cannot drive the car really right now
http://www.mercedesshop.com/shopforu...ht=seat+switch
When the switch needs cleaning, usually only one or two movements stop working. It's not all or nothing. A failed switch does not necessarily cut power off to the seat. Just my 2 cents!
If that's what you mean then yeah. The switch has nothing to do with it. I'll leave my previous post to cover both bases.
Ha ha, now that I think about it... I've noticed that my driver seat is very unlevel. It actually makes me lean towards the center of the car and my back starts to ache after a while. I thought this was due to the fact that I installed some sound deadening material that required me to remove and re-install my seat. But I guess it very well could be due to the same problem you're describing. Would you mind linking me to the "other forum" where you've also posted this? lol, thanks!
Thanks Gilly for the reply over there!
@ Pete yea that's the same problem that I had, let me ask you this, when you try and push the button for the rear of the seat up or down, do you move up and to the right/left and down to the right/left rather then just up and down, if so then I think you have the same issue that i'm having, and yes it can be quite uncomfortable when you are sitting at an odd angle... Best way to check is to put the seat all the way forward and then be behind the seat, take a look at the two "arms" for lack of a better word, at the back of the seat they are connected to the lower track, now have someone push the button to lower/raise that part of the seat, if only one moves or, if they don't move together then yea my guess is you're in the same boat. I will post a small video and pic to help illustrate what is going on that way anyone else who might have this problem, can tell right away...
http://www.mercedesshop.com/Wikka/W123SeatRepair
http://dieselgiant.com/repairseatspring.htm
hope that helps.
My problem may have to do with the fact that I added some sound deadening material to the floor and then reinstalled the seat. The problem was obviously worse after I did that. But it was definitely present before. My wife once told me when she drove behind me that she thought I was trying to look cool and lean in towards the middle of the car. ha ha, it definitely wasn't intentional! But now it's bad enough that my lower back starts to ache after driving for a while...
I got your email, btw. I'll send you that file when I get home in about an hour.
hmm, that does sound like your maybe having the same issue as me then, just maybe to the other arm not the same one as me. Tomorow when fixing it, I will take pics while it's being done, and do a little writeup about the procedure as well and post that, that way those who think they are having this problem can tell for sure.
