Timing resistor
Now I do recommend that ya'll check your timing as you may be over advancing on some engines w/ the resistor pulled while others come right into spec.
Here is what I have for timing maps and their resistance:
0 - 145 ohms ~4atdc
150 - 330 ~0 tdc
350 - 675 ~4btdc
680 - 3.0k ~10btdc
3.2k - 0pen ~15btdc
This was off of a 420SEL which should translate to and CIS E car.
The 12 degrees is where the Euro's come set, and that's the theoretical ideal thus it's where I shoot for.
If y'all don't think going from 2-3 degrees initial to 10-12 makes a difference get into an older points car and retard and advance it accordingly...You'll notice the difference straight away.
Jonathan
0 - 145 ohms ~4atdc
150 - 330 ~0 tdc
350 - 675 ~4btdc
680 - 3.0k ~10btdc
3.2k - 0pen ~15btdc
Jonathan
Love the info. So when you say open is almost 15btdc is that w/out the resistor? I am running high octane and have no pings, i'll check the timing tomorrow. But I could always run to radio shack and get a resistor and solder it in there and check for a varying in perf. "over advancing"? 15btdc is pretty advanced if you ask me. clarify please?!
