Low enough?
I have had my car lowered for over 6mths now on H&R springs, coupled with Bilstein Sport shocks all around.
I haven't fiddled with the bump pads at all so all should be the stock bump#3 bump pads.
Now that I'm sure the ride height has settled, I was wondering if my car would look nicer to be lowered more.. If so, which bump pad would you recommend me using?
By the way, how much difference is there between each bump pad?
Now for the pics!
Cheers,
Jeff
Also, how much difference, in terms of height, is there between, say bump#1 and bump#2 pads?
In regards to the ride quality, it is fine.. Nothing exceptional.. To say that it is just as good as stock is a lie however, it is not too bad.. The Bilstein Sports help a lot I would say.. Anyway, I'm sure the ride quality isn't one that someone couldn't live with!
Jeff
-OG
Anyway I guess I won't lower the front more, I'll just lower the rear by a bit.. Maybe 1cm?
And in regards to rubbing, no there's absolutely no rubbing. Choosing the right rims is the key
Cheers! Will do!!
I love the car but was just wondering if it would look better if I lower it just a tad more.. hehe..
V9, my wheels are AMGs (duh.. just to be clear!!)..
Fronts: ET37, 7.5*17, running on 215/45/17 Pirelli PZeros (rounder side wall, elimination of rubbing)
Rears: ET37, 8.5*17, running on 235/40/17 Pirelli PZeros (reason for choice of tire is same as the above).
Hope this helps!
Cheers!
Jeff
Hope this helps!
Cheers!
Jeff
