Engine Cuts Out
Now that I've discovered the kickdown switch, another issue has come up.
So, I'm flying along with the RPMs in the red, pedal to the metal, and then the transmission shifts into 2nd (or 3rd). As soon as the shift hits, the engine cuts out for a half second and then it's right back at it again. Sometimes it cuts out and resumes twice before it lays into it again. It's not like a spark misfire; the engine actually goes dead for about a half second. It only happens during a hard upshift when the RPMs are close to or in the red. It is fairly consistent, although it does not cut out every single time. During normal driving the engine runs so perfect and smooth it's scary. No CE light; no codes stored.
I've examined the heck out of my harness and I have never seen any copper showing or signs of damage. It seems a bit stiff where the wires connect to the 3 ignition coils but not frayed. I've tried wiggling the wires in various places with the engine running and have never triggered a misfire or cut out.
I think the spark plugs may be the original as they are rusty around the ceramic on the outside of the plug. The combustion end of the plug has the usual white buildup but no sign of worn electrodes. They are Merc plugs. I only have the service records from 138,000 miles (now 157,500) and no plug changes were done. If this problem were caused by old plugs I would think it would misfire under other conditions as well. The previous owners did all the maintenance religiously so when ever the recommended change interval is (if it's recommended) they were probably changed.
As I mentioned, the engine pulls strong up to the point where it shifts, so I don't suspect a clogged fuel filter. I can't think of anything else except some wierd computer or electronic problem. I know that the engine will faithfully cut out when it hits the middle of the red to avoid over-revving, as it does this when stuck in the snow (big blizzard recently).
Has anyone else experienced this problem?
Pay close attention to the tach...Shift to second gear occurs at 6500 RPM, well into the red, but no cutting out. Mine does the same, but cuts out when the RPMs drop after the shift. You're saying yours all shift at or before 6100 RPM? I didn't think that was adjustable. Changes to the Bowden cable adjustment seem to have no effect at WOT.
Forget the red line thing; that is not the problem because it does not cut out until the RPMs drop to 3500 or so AFTER the shift. The hard shift seems to trigger the cut out.
Also, I forgot to mention that this cut out also occurs occasionally and much more briefly on a forced kickdown. The RPMs jump up to say, 3500, then quick pause (quarter of a second) then hauls a$$ down the road.
Side note: My car feels like it gains another 20 horsepower as soon as it passes 3500 RPM. You can feel it kick in every time like a switch. Is there variable valve timing or something like that?
I noticed today that this cut out seems to only occur, or is at least more noticeable, if I let off the gas slightly before the shift. I sometimes chicken out for fear of the sheriff lurking around. I guess I won't worry about it. No one is likely to challenge me to a drag race out here in the burbs, anyway.
Next project: engine mounts. They are both cracked and giving me a hellacious massage while sitting at stop lights.
Uh, that's not right. 3 in my family and none of them do that.
