10 Degrees Caster? Anyone tried less?
The caster spec is about 10 degrees for a 124 but most other cars are 3 to 4 degrees. I'm about to have the car aligned (got new tires and wheels) and I was thinking of telling them to set the caster a little less.
Anyone tried setting their caster a little less than spec?
Also, I hope one spare eccentric bolt is enough for an alignment.
Besides my shop said they would do a "just toe" alignment cheap if I have them replace the other tie rod later.
With used AMG wheels (ebay), new Nitto tires, tensioner and belt, the other tie rod would put me over the $2k limit the boss gave me (unless I want to manage the money and do the taxes which I don't).
I got one front and one rear new eccentric bolts in case they have to bust one to do the alignment. I hope thats enough.
After that, I need euro headlights, need to find my short and Bessy is tip top.
Say do you know how to get the drivers left kick panel off?
How hard was it to pull up all that carpet to get under the back seats?
The kick panel you speak of, are you meaning the one to the left of the driver? That one is a bit tricky too. Again you need to remove the platic door sill cap and partially remove the windlace, at the bottom corner that is now exposed you should see a small screw holding into to the body. It has been a while since I did this last, but you also have to pull up the carpet mats and there will be a thumbscrew holding it down to the floorboard/firewall
I can't recall if you need to remove the underside of the dash or not.
