ABS light is on?
Hoping it's a cheap fix.
. When I am driving, it seems like the car is gently braking or holding back on me. When the light goes off (after a few minutes) it feels like I gain about 20hp back. If only it were 5 years from now, I could diagnose and fix this in a jiffyTrending Topics
LOL /rant
Anyway, maybe the fuse, or, if you check the manual, the ABS light comes on randomly when youre alternator can't charged to specs...
I've been there. The engine would stall randomly, with light coming on in the dash... Got quick under the car, scared as hell, because like Zorro said, it aint no joke, and started searching. The alt. was to blame, because I figuered that it only came on when I was using all off my comfort electric things. It was ok with the A/C on, radio, headlights, and when I rurned on the heat in the seats, everything whent wild... So I went on and replaced alternator, and it got all good again.
I dont know...worked for me tho
The OVP runs almost every electrical circuits on your car.
OVP= Over voltage protector.
It is located behind a black pastic cover, behind the battery.
It has 1 or 2 fuses on top.
it looks like this
Pull the plastic cover off behind the battery and locate the OVP relay. Sometimes they're difficult to re-install, you should be able to figure it out. it could be a blown 10A fuse it replace both pf them if you have 2
