Home made spring compressor
I was stuned by the prices of spring compressors so has i had nothing to do this past weekend i made some home made spring compressors,
used a M20 screw, 2 nuts, some pipe and 10mm metal sheet, here's the result:
This is the rubber i sawed off:
My spring compressor won't work on the w124, so I just compress the a-arm with the jack and release the pressure that way, it is so simple and free.
edit: good job mouramen, i'm not sure i would have the ***** to trust nothing to pop off, but there's nothing like doing the job yourself, let alone making the frikkin tools too!
Watch this....
http://www.youtube.com/watch?v=yjkTSFmmE6E
Watch this....
the details. there is a gamble involved just as there is in crafting your own
spring compressor from scratch. provided all is done with attention to
safety, and with sufficient safety nets, either of the above can be done.
i've actually found that lowering the control arm *and* compressing the
spring...both aids in ease of spring swap. since I have been doing my own
lowering (sampling different springs, swapping out spring pads, as well as
shocks) I'm actually quite adept now. coincidentally am doing my final
spring/shock change tomorrow. I've alotted approx 3 hours total for both jobs.
but i digress: spring change w/o compressor... my recommendation is to use
two floor jacks to assist in maintaining alignment. think twice, proceed
carefully and slowly.
Fronts are tricky like said but its easy if you go slow. Do it once and you're a pro.
