Need help with radio swap for W124
...but still no power at the ignition wire
What the heck could be the problem? The original radio was working fine!
I'm almost there!
Perfect!
Now that I got power I can start trying to get the speakers to work hopefully.
I'm trying to figure out which wires are for the front + rear speakers...Is there somewhere that shows how to do this? The DIY link earlier shows a fader...but all my wires are a different color.
I tried a few combinations, but didn't have any luck. I tested an old speaker lying around and it worked...so its just me having problems figuring out which wires are for which speakers.
Also same goes for the rear....Do the front speakers go to the fader along with the rears? I'm still not too clear on the wiring.
1/2 way there!
So all I need now is to find the rear speaker cables at the fader, correct?
Once I get this figured out and done, I'll do a write up so its super easy for anybody else who wants to do it for an early w124.
Either way I am very happy!
Here is a very and easy summary for anybody who searches so my 3-4 hours spent doing this could be done in 30mins tops (seriously)...
You DO NOT NEED to purchase an aftermarket $25-$30 wiring harness. This can be avoided....albeit a little more messy, but I wont be swapping the headunit ever again, so who cares?
This will work on 87 and earlier models I can tell you for sure....not sure about later years as I have searched, and some W124 models use different colored wires at the Fader...so this should clear up much confusion for the earlier models. This also "should" work for all NON-OEM-Amp setups with only a change in the fader's wire color. You can determine the new color by simple elimination. Just do all steps and skip the fader until the end then just cut it and do one-by-one while playing music til you find the right wire.
Disclaimer: Please remove negative cable from battery while doing this and ensure you have a fuse built into the headunit, or add in your own on the +12V constant wire.
Step1: Remove shifter + A/C wooden cluster then Cigarette Lighter. There is a DIY on this.
Step 2: Remove OEM Becker Unit. Remove power cord, Speakers L + R (2 channel), Chassis Ground and the Antenna.
Step 3: Cut the original Becker power harness off -- It will have 4 (four) wires. Wire them up with harness on new headunit.
OEM-Harness-Side:
Blue = Power Antenna
Brown = Ground
Red/White = Ignition +12V
Yellow/Black = Constant +12V
There is no illumination wire if your harness has one.
So match the names with the new harness. Pretty straight forward.
Step 4) Now head over the fader. Cut it off completely and pull out the following wires:
Black/yellow (+): power to left rear speaker
Black/white (+): power to right rear speaker
^ (Thank you to BodhiBenz1987 for the correct wires)
These are the only two wires you need. Tape up the exposed remaining wires for safety reasons.
Step 5) Run new wires from the Black/Yellow and the Black/White up to the headunit. Tape/Solder them to the positive wire for the respective speakers as shown above on the hew headunits wiring harness.
Now, behind the headunit, there are a total of 4 (four) little connectors as shown in the picture below:
Above you can see the male and female connectors. You only need the male one.
Front speakers: They were directly plugged into the 2 channel L + R in the beginning. Simply gut the male connector and attach the green to the positive (+) and the black to the negative (-) on the new headunits wiring harness. On the little male connector, it will have a L or R imprinted on it so you can tell. I would label each connector with tape for ease at a later date if anything comes loose or w/e.
Rear Speakers: There is NO grounds at the fader....instead, you should now have TWO remaining speaker male + female plugs left behind the headunit. Each of these will still have a L or R written on them. You are ONLY using the ground (black wire) from these. Wire the grounds to the new harness. Now, take your new extended positive (+) wires that you made from the fader, pull it behind the headunit and attach it to the positive (+) for each speaker wire at the new headunits wiring harness.
At this point the speakers should be working fine.
Step 6) Attach Chassis ground (my headunit had a bendable piece of metal that it attached to...Had to pry it up)
Step 7) Attach antenna
Step 8) Test if you have not already.
Might be a little confusing....but print it off and read it with yourself in front of the wires. Ask me if you have any other questions.
If anyone needs help with this just let me know.I'm currently trying to install an aftermarket radio in a 92 300E. the problem i'm having is my antenna doesnt look like any i've seen with the adapters. it doesnt have a single small nipple, it has several prongs. does anyone know where i can find an adapter for this? thank you
Today, I sent 2 wires from the amp to the battery (positive and ground), and a wire from the radio to the amp. Then, I simply connected the sub to the amp.
So the end result is, I'm using Pioneer speakers (nothing fancy, medium quality stuff) connected to the amp/sub.
I really don't see what the problem is. There are more W124's than Beetles here in Lebanon, no exaggeration. Everyone knows how to work with them and I've never heard of anyone with a problem.
The only thing I can thing of is that your cars in the US are double dimm (if that is what it's called) and therefore might make it more complicated, but I don't think it should.
Question 1:
If I go with the JVC KD-R900, would I need to rewire the speaker wires? My car doesn't have the infamous center console fader switch, and it has 2 factory amps on the right rear tire wall. I'm hoping it'll be a straight install if I can find all the needed wires from the back of the bose unit.
Any thoughts and/ or diagrams are much appreciated.
Question 2:
Will it be a straight connection with the new Blaupunkt unit? I mean would the wire harness from the Bose unit fit perfect into the new Blaupunkt unit?
Here's a link to the Blaupunkt unit: Blaupunkt: Bluetooth Tuner[view]=1353&no_cache=1&L=1
I want to equip this car with a decent bluetooth cellphone capability so I don't have to rely on those spotty Motorola bluetooth microphones.
Much obliged!
