92 300E Speakers!!!
Old Oct 16, 2002 | 12:34 AM
nizmo's Avatar
92 300E
Exclamation 92 300E Speakers!!!
Does anyone know how to take out the 6 speakers on the 92 300E. I brough speakers and amp and i need to know how to hook my speakers up..Please help.....THANKS ALOT.....
Old Oct 16, 2002 | 10:39 AM
CME4BENZ's Avatar
All of the above
124 speakers
There is a thread in the audio section specifcally about W124 speaker installation. Look in the old threads for audio.
Old Oct 16, 2002 | 11:20 AM
chupper's Avatar
Check this out
https://mbworld.org/forums/showthrea...threadid=19511
Old Oct 16, 2002 | 12:03 PM
nizmo's Avatar
92 300E
well, basically, i installed a head unit already and it's working good....i had and easy way out on the rewiring the car....but rite now i don't know how to take out my speakers because i wanna swap new speakers in there.....also i need the sizes of thoese speakes......but i hear chupper that he did some metal cutting and stuff.....is there any easier way to install those 6 speakers??
thanks for the help guys!!! THanks Alot!!
Old Oct 16, 2002 | 01:49 PM
CME4BENZ's Avatar
All of the above
Check out this thread
Nizmo,
Check out this thread. Click on the link in the second post.
https://mbworld.org/forums/showthrea...threadid=11799
Old Oct 16, 2002 | 10:01 PM
chupper's Avatar
Removing Your Speakers
Nizmo-
You want to remove your speakers?
You have two options.
Option One-
You could care less about your current OE speakers and will throw them out when you're done with this.
Option Two-
You want to keep you OE speakers for some reason.
Option 1 Instructions:
Take a screw driver and rip open the cone. Stick your hand inside the speaker and rip it out. It will pop out (the ones in my car were held by springs)
Option 2 Instructions:
Carefully find where each spring is located and carefully pry that area of the speaker out. When removing speakers near your windshield, be extremely cautious as they can come popping out so fast that they hit your windshield and can shatter it.
Option 1 is easy, and that's what I did. The speakers are stinky, so throw them out if you aren't going to use them.
Good luck!
P.S. My metal cutting was for INSTALLING the oversized speakers. This was quite difficult and cause a few cuts on my hand. I used a hacksaw, a wrench and my arm. I just kept cutting and tearing until I had room. Once your done, it doesn't matter. Your mess is covered up by the nice matching grill guardes The only way you could see your bad cutting job is by sticking your head in the trunk and carefully looking for your speaker holes. It's worth it to cut if you have to, no one will notice.
Old Oct 17, 2002 | 05:37 AM
nizmo's Avatar
92 300E
Thanks alot guys!! thanks for the info....do know how to take the speakers off the front doors??? thats the only one i'm stuck now....and also is it possible to fit 6 x 9 @ the rear speakers??
thanks!
Old Oct 17, 2002 | 11:26 AM
chupper's Avatar
Hmm...
assuming your 92 is the same as my 89, you can only fit 5'' speakers in the rear without cutting.
As I said, I cut, and was able to fit in 5 1/2. Those were circular. The 6 x 9s are oval, so...
You can, but it will be EXTREMELY difficult, and wear some work gloves.
