What is the difference between a w124 and a w210 e320?
Techonologically, the W210 cars are more advanced, but also can have a host of expensive issues - I own a W208 - with LOTS of computers too! Instrument clusters on the later W210s have a high failure rate and the dealer will tell you the only fix is replacement. Big $$$.
All W210s have water based paint...I think MB went to that in 1995 or so.
Cap'n Jasper mentioned rust...that is a real concern for the W210 and there have been many reports of spring perch failures as a result of rust and/or problems with the welding.
Whereas the W210 has it's share of issues, the W124 is not immune. Wiring harnesses, oil leaks, a/c problems, etc.
Seriously, you have to determine what your needs are - whether you want a W210 or keep your W124. FYI, my 1991 300CE has cost me nearly $30,000 in receipts for maintenance and repair for the past 12 years and 150,000 miles I've owned it. Would a W210 cost any less? I don't know.
I will say this.....a well maintained W210 is going to be less costly and aggravating than a poorly maintained W124.
If you are a DIYer, my sense is that the W124 will be easier to repair - saving labor costs - over a W210, simply due to the less-complex systems and expensive diagnostic tools that would be required to service and repair a W210.
Spring perch info:
http://www.mercedesshop.com/shopforu...t=spring+perch
touch wood my w124 has not had any problems so far at all, and i only do regular maintenance on it. mind you, it doesn't want to start every now and then, but i haven't figured that one out yet.
find a car with good maintenance records and get it checked by a mechanic before you buy, and you'll be good.
I personally think the W124 is one of the best looking sedans ever made. On the W210 the spring perch issue alone would probably keep me away from those, as long as there are still W124s in good shape to be had.
IMHO, BMW and Mercedes have let their build quality down... the last good bmw (to enthusiasts anyway) was the e34 (aka the 89-1995 5 series). The last good MB... was our 124s... also made in 1995.
I hate how germany is going now a days... for example, german cars DON'T have cup holders!!! They should stop trying to adapt their cars to stupid marketing and go back to rock soild, over-enginerred tanks of the 70's and the 80's... Personally, I like my c230k.. but its too complicated. I prefer my w124 and my older bimmers (aka the e34) anyday.
.when the 210 came out, lexus had been decimating mercedes sales for about 6 years here in the states. development may have started prior to the debut of lexus but it was far from complete. it was immediately made cheaper.
the 124 had pretty much all mercedes' known technology thrown at it in 1984. not so with 210
