My 500E RWR Supertouring.
#678
I think those DTM diffs come off the 190e DTM cars. I saw a 5.0 diff for sale on Ebay a few years ago but I simply could not afford the money. I regret not taking out a loan for it to this day -_-
#679
1 Post
C43 T AMG -98, 500E RWR -91
Well... there will the a new subframe whith dubbel wishbones. So there will be al new i the rear and the front... same set up in the front..
Thak's alot for those words!!!
As you said... it is from a 190 DTM EVO 2 car!!!
#680
300D, 500E, E420
Is the DTM diff a 210mm? What gear ratio? And what's the advantage, compared to just installing a factory LSD (or custom Quaife, etc) into the standard 500E diff housing? Oh, and if the DTM ratio isn't what you need... what ratio are you looking for?
BTW - awesome photos of the project, keep up the great work!
#681
1 Post
#683
i would like to ask you a favor.
once those intakes are in and the car hits the road.take avid of it.but you will have to rev the nuts off that engine for me and let me hear it please.
just awesome
just awesome
#684
Noob question, but I am still wondering about that diff. what would be something similar or equal I know it would be a fortune to get a DTM one.
thank you. keep the pictures and updates coming please
#685
300D, 500E, E420
BTW - what is the Mercedes part number stamped on the DTM housing?
No, not off the shelf they don't. But I believe if you send them the "open" carrier, or an entire 500E diff, Quaife will custom-make anything you want for your diff housing. I think the cost is fairly reasonable too. However, if you want a super-low gear ratio like 4.30, that could be a problem... most factory ratios are 2.xx or 3.xx (which I'm sure you already know!). That may not be an issue if you can adjust the transmission gearing accordingly. While custom LSD units are not a problem, having custom gearsets made could be a lot more difficult (and/or expensive).
#686
1 Post
210mm refers to the diameter of the ring gear. Mercedes used 185mm ring gears behind most engines under 200hp, and the larger / stronger 210mm gears for engines over 200hp. The 500E comes from the factory with a 210mm diff, and a 4-bolt input flange. The photo of the DTM diff looks like a 185mm housing, and it has a 3-bolt flange. I'd just be concerned if it's 185 or 210mm gears inside... I'm not sure a 185mm will survive behind the moster motor your're building! If anything, I thought you might want the reinforced 210mm diff used with the M120 engines in the R129 / W140. See attached PDF file.
#687
2006 A180 CDI - automatic
This is one Cool project you're doin' man! I love this idea of making a saloon car a Barely Street Legal race car ........you guys are doing a marvelous job too ! It's Looking Great ! I for one will love the vids when it's finished
#696
560sec 126/ 500sec32v race car
Hi how much to make a 2nd intake manifold at present in my class we are only allowed 4 throttle bodies
But i have been buiding a 119 6 litre engine and will be changing classes and will need 8 t/bodies
i have a very similar clutch set up mine weighs 3.7kg with clutch
Im using a 126 diff carrier with 3.96 gears from a 210 chassis and its spooled
never broken it yet and its had a lot of race abuse almost the same as a 129 carrier and housing
I have had valves check by the best cam designer in NZ and we have both decided standard size valves will flow in excess of 650 hp so they designed and made me a set of cams and supplied 2 piece race springs the cams are that big i had to cut a lot from the cylinder head so they would actually turn
Im hoping this engine will make the 650 hp i desire and need to win here
Keep up the good work
Tim
Tim
#697
lots of cars
Quote:
Originally Posted by ZedStyle View Post
the new God in the church of W124
Well... I don't know about that... but thank's!!!
#698
1 Post
Tim
Tim
Thank's man... I hope this one will be remeberd... and my contact at AMG in Germany are also excited to see this one done... so the first stop is AMG, Germany!
