95 E320 Wagon springs/shocks
ASAP.. I know that I can get springs and Struts for the front.. The rear
has the SLS. Does it work with aftermarket springs?? can it be converted to a
standard shock/ spring combo?? i am gong to fabricate a new rear section
for the exhaust. Do intake and exhaust mods give a bit more power or not?
any help is appreciated
Marc
When you get the car you'll find the factory 3.2 torque monster pulls rather well against ANY six out there. Guys here are not too engine "mod" nutty. Anything past your standard cold-air intake and high-flow exhaust tweaks are marketed to the tuner crowd, not Mercedes owners. The aftermarket is very limited looking for "Superchips" or Nitrous kit products. Mercedes is a whole different world.
You can spend $300 modding her for noise and 5 HP. Feel free to tweak the suspension and remove factory engineered leveling and safety features. (What do those Germans know anyway?)
Save your bucks for getting it tight and right, then review any major mod carefully.
Its a bit involved (but easily done) to replace the rear SLS with conventional shocks.... worst is changing to a non-SLS pump on the engine. Does your SLS not treat you well tho?
The tough part is replacing the SLS/steering pump to one that is for a car without the SLS specific pump. I don't think you can just plug off the SLS fluid lines.
The pump is easy. I have a standard W124 Power Steering Pump that will directly swap onto the motor to do away with the tandem pump.
I would use Bilsteins if you are asking me my opinion. Whatever fits will work though.
Adjustable Konis are a bit overkill no? But if you have them already use them. At the time I was thinking of deleting my rear SLS there were no Koni adjustables for the 500E...but I did put them on the fronts of my car. They really are nice for track and auto-x days.
