engine oil & transmission oil w124
http://www.datateck.com.au/lube/mobil_au/
this tool is saying 10W-40 for my car. Who si stupid here???
In my opinion 15-w50 is to thick.
For transmission it says ATF 220 is this Dextron II???
What do u guy use and what do u recommend as my w124 has only 49miles on it i would not want to harm it
Cheers!
Cheers!
Transmission is funny as well, like castrol books recommend trazmax M and everyone else dextron II, this weekend i'll change it to dextron II. Dextron III is i believe more for 5 speed.
I don't think you can get Dexron II anymore. Dexron III supercedes Dex II, is backward compatible, and should work fine in your transmission..
I have all books for this benz since it has been purchased (i am second owner) i could not find anywhere recommended lubricants....
You guys think brand of oil is important, i want best stuff for my benz but at the end they could be all the same, coz oil companies probably have independant test to make sure oil is up to standard.
