2PHAST, V8 in W124?
Old Oct 9, 2007 | 04:15 PM
Chappy's Avatar
AMG
Originally Posted by ZedStyle
there's a guy in the 190e forum putting a v8 into his car too
Cool...I ran against one at an MBCA event six years ago. "Tobias" had a Ford V8 with a sequential shift in his 190E race car.
Old Oct 11, 2007 | 09:39 PM
STLe320's Avatar
95 e320...sold the rest
Originally Posted by Rio Z Lander
i dont know i beat a 260e with mine the other day and can can go 140mph +and the car dose not strain. did a burn out in 1st 2end and part of 3rd this thing jumps to.
correct me if i'm wrong...but don't these start out in 2nd?
Old Oct 12, 2007 | 09:21 AM
shadowgriffen's Avatar
is a German Tank
LOL correct.
Old Oct 12, 2007 | 11:16 AM
carlson03's Avatar
03 ML500
you can start on in first gear if you shift to the lowest gear (2 on my car I think), then shift back to drive
Old Oct 12, 2007 | 02:10 PM
ZorroAMG's Avatar
Enzo, my Benzo
Stormy, if you de-jbwelded your car you'd know you can get it to start in 1st every time.
Old Oct 12, 2007 | 03:12 PM
is a German Tank
Doing that is just plain
Old Oct 12, 2007 | 04:25 PM
  #32
2PHAST's Avatar
500E Signal Rot
Depending upon the year of production, your vehicle may start in 1st gear or 2nd. I know that the 1992 2.6 190e started in 1st gear by default, it may of been that way on the 90-91 but have not verified. My friends 1992 300e, starts in 1st gear by default. So I have to assume here that the later models were changed from a 2nd gear start to a 1st gear start.
All 400e/E420s start in 1st gear, all 500e/E500s' start in 2nd gear. (92-95)
Old Oct 12, 2007 | 08:59 PM
  #33
MediumKahuna's Avatar
92 300TE 4Matic
My 92 TE 4-matic (3.0) will do 135 mph and its worse than stock (needs work).
Of course the 4matic won't let you break the tires loose.
Old Oct 22, 2007 | 04:53 PM
  #34
McBear's Avatar
500E's
Originally Posted by Mazinger
My 400E engine is starting to have rod-knock, I'm still debating whether to fix it (doubtful, with the alusil and all) or swapping it for another m119, anyone know if I'll run into trouble with a ASR m119 from a W140 or similar?
Depending on a bunch of variables, you most likely don't need to look at re-Nikasiling the cylinders unless there is serious wear/gouging.
With that in mind, you should only have to replace the offending rod [or all the rods with lighter weight ones] to eliminate that issue. Your R&R time is going to be the same [about 50 hours - book] but if you rebuild you current block, you will kNOW what you have [head job, new rods, new gaskets, sending units, chain, guides, etc] whereas if you get another engine you may, or may not have to address some of the same issues.
Unless I had a catastrophic issue with the motor [crack, warp], I would rebuild what I had so I would KNOW what was in there. You will end up with a completely refreshed block/heads which should give you another 200K miles.
Old Oct 22, 2007 | 05:46 PM
  #35
Mansoor 300's Avatar
91 300E
forget the M119 motor, just drop in a LS1
something I'm trying to get into.
Old Oct 22, 2007 | 07:30 PM
  #36
jlink38's Avatar
E320
meh i don't know much about the motor. all i know is it is fast and thats all that matters that and it still runs good. the other day i hit the gas and the tires spun for 3 seconds then did it again in 2end and 3rd. no more than a few seconds in each gear i don't mean one burn out in all 3 gears i was short on time when posted that i needed to head back to class.
Sounds like you need some new tires.
Old Oct 24, 2007 | 07:20 PM
  #37
enderw88's Avatar
95 E420/98 ML320
My 95 E420 starts in 2nd unless I specifically kick it down prior to launch...
Back on topic, my E420 also has a CEL that is pointing to the transmission. I have been unsuccessful in finding a junk transmission, so may just swap the entire thing out for grins. Wife would probably kill me since she says no more projects (just 'finished' a Stalker)...
Any serious firewall mods to fit, say an LS1, in a W124 that already had a V8?
