Hard Cold Start
Old Nov 7, 2007 | 07:00 AM
kenshaaka's Avatar
w124 e280 1994
Hard Cold Start
When I start my Car cant idle until when it warn. So I have to step the gas until when the temperature needle nudges to around 40 then I can let go of the pedal. Otherwise it shuts down. Recently changed plugs and fuel filter. What could the issue be?
Old Nov 7, 2007 | 11:12 AM
jmoney6's Avatar
1993 Mercedes 300e 4-matic (m103 motor)
voltage relay..Located by the bttery.silver rectangle with red top and 2 fuses on top/
Old Nov 7, 2007 | 12:01 PM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
Cold start valve
Old Nov 7, 2007 | 01:36 PM
shdoug's Avatar
1995 E320 SE, 162,000 Miles (Sold) 2007 CLK350 Cabriolet 2014 ML550
I nominate the idle control valve. The cold start should not be active when the key is released from the start position, right?
Old Nov 7, 2007 | 02:19 PM
RBYCC's Avatar
I believe the cold start enrichens until the temp sensor takes it out of the circuit.
Old Nov 7, 2007 | 02:57 PM
appatula's Avatar
95' AMG SeeThreeSix
The cold start valve is powered by the fuel pump relay. From the diagram it does look like the coil wire in the fuel pump relay is activated by the ignition switch at position 3 upon starting. Thus the Cold start valve seems to be actuated upon starting action only (when starter motor is actuated). Idle control valve may be the legitimate gremlin in this case?
Old Nov 7, 2007 | 04:06 PM
RBYCC's Avatar
The cold start valve gives about an 8 second shot depending on ambient temperature.
Acts like a choke in a carburetor.
Enrichens enough to stabilize idle until the temp warms up.
I reread the OP and noticed the vehicle is a 1995 which would have HFM injection.
HFM doesn't have the cold start or idle control that is used on the CIS-E.
It has a mass air flow sensor
HFM is fully electronic.
My comments were to the CIS-E
Old Nov 7, 2007 | 07:20 PM
appatula's Avatar
95' AMG SeeThreeSix
ahhhhh see what happens when I think everyone rolls in a 86' 300E!!! haha, while on the subject however would my assumption be correct pertaining to a CIS-E injection like mine, or there is a 8 second timer? Where is this in the schematic or is it a signal sent from the KE control unit?
Old Nov 7, 2007 | 08:30 PM
shdoug's Avatar
I didn't notice that it was a '95, either. Then your comment about the cold start valve distracted me as well. So we've probably helped someone else with a different car but with HFM, what do you think about the Temp Sensor? I'm thinking it could give a false reading and make the controls think the engine is already partially warmed up.
Old Nov 7, 2007 | 10:49 PM
YNVDIZW124's Avatar
lots of cars
I would think it would be easier to find out what's the problem with his car because he could check for codes. That's the first thing I would do..
Hey I roll in an 86 300e <<<---- LOOK..lol....There aren't many of us left....
If he has a m103 engine It should be the CIS Temp Sensor at the rear of the engine. If he has a m104 then i really have no idea where this would be...
On mine i have 2 temp sensors the green one in the middle of the engine but the important one is the one at the rear with the two posts on it. That's the one that controls how rich or how lean it is on starts.
Old Nov 8, 2007 | 01:31 AM
appatula's Avatar
95' AMG SeeThreeSix
not to steal the thread but where is this sensor in the rear that conrols mixture upon startup? I have a cold start issue and am trying to compile a list of things to replace and ive never heard of this sensor
Old Nov 8, 2007 | 02:25 AM
YNVDIZW124's Avatar
lots of cars
This tells the computer when the car is cold or hot and controls the idle speed. If your car idles around 800-900 when it's cold then it means it's working. If your car only wants to start when it's warm then it means this is not working. The green temp sensor is for the aux fan and the temp gauge and has nothing to do with the cold start part of it.
Old Nov 8, 2007 | 07:45 AM
RBYCC's Avatar
The enrichment doesn't really come into the starting circuit unless the water temp is less then 20deg C. ( 68F).
The temp sensor ( via KE control unit ) cuts it out once the water temp exceeds this setting.
Max time to reach this water temp is calculated by MB at around 8 seconds.
Old Nov 8, 2007 | 01:09 PM
shadowgriffen's Avatar
is a German Tank
All this reading is giving me a headache
Old Nov 8, 2007 | 01:13 PM
is a German Tank
two fuses??? I've only replaced one and have only seen one
Anyway, I put my money on the relay as well.
Old Nov 9, 2007 | 01:06 AM
kenshaaka's Avatar
w124 e280 1994
Recently Changed the Relay. Could it be at fault again? My Mechanic doesn't have the cable for these cars otherwise I would check the codes. Does anyone know where I can get the cable? I could hook it up to my laptop since I have Carsoft.
Old Nov 9, 2007 | 11:05 AM
is a German Tank
Have you jumped started the car lately? Regardless, you should check out the FUSE instead, could very well be.
It doesnt hurt to look, it'll take you five minutes the most.
Old Nov 11, 2007 | 11:39 PM
kenshaaka's Avatar
w124 e280 1994
Yes I recently jump started the car. Which fuse should I check?
Old Nov 12, 2007 | 08:39 AM
is a German Tank
Check the OVP relay fuse, even if they've replaced it.
Jumping the car can blow the fuse, hence the OVER VOLTAGE.
