Limited Slip Differentials for W124's??
#201
1993 W124 300E 2.8
The ASR system is even better. Now that I've got a couple of E420's with ASR as daily drivers, I'm sold on ASR for winter use. It's plain awesome.
It's a whole different story with ASD, which locks the diff and will take advantage of any tiniest bit of traction on any of the driven wheels.
Of course - a 4matic would be perfect but there's always a price to pay.
The only way I'd even consider attempting this conversion is if you were able to get a compete donor car that you could swipe all the parts from. And I wouldn't want to be pressed for time, i.e. have to go get everything off the car before it goes to the crusher, etc. That's a surefire way to miss some little required item, lol!
Since ASD cars are much more common in Europe, it shouldn't be too hard to find one to replace your non-ASD car.
The only thing I am concerned about is - whether my 2.65 diff with an ASD carrier is going to work with the system. Housing is the same - ASD generally works in the area of the flanges (?). Nevertheless I've seen ASD diffs to have a sort of a metal line connecting the right and left flange and I am not sure which element this could come with.
For example here(even though this is actually a 185mm diff):
I don't see it in the EPC:
Does the hydraulic system connect to the flanges?
Thanks for all the information.
Dave, by viewing your site, reading all those articles and seeing the modifications pictured I've really entered a new era in my Mercedes adventure. Thank You for that. I am learning something everyday and when I cannot figure something on my own, there are few things that your site or the forums cannot help with.
#202
300D, 500E, E420
I've driven an ASR equipped car and just let me tell you this - when you're driving up a snowy hill and one wheel has really poor traction, ASR won't be able to help you. It just cuts on the power, but it's no use - you're going slower and slower up to the moment when the car stops, traingle flashes and nothing happens.
#204
300D, 500E, E420
Oh sure, you can buy all the parts to replace the clutch pack from any Mercedes dealership. But it is a LOT of work, and some special tools will have to be purchased or fabricated. Pics on my website (here) show the various tools, as well as the clutch discs. All the discs have to be purchased individually. Probably $250-$300 in parts depending on where you buy them.
#206
quaife 3.69
Hi everyone,
I have a 300-24 with a 3.69 diff and am interested in the quaife LSD.
There was a previous post of which ratios would work with the quaife but I thought it best to double check.
Any opinions on running the quaife on the 3.69?
Or will the 3.07 be the closest option for plug n play?
Thanks.
Thanks.
#207
300D, 500E, E420
The Quaife QDF5V is plug+play only with early 210mm diffs, and only with 2.65, 2.82, and 3.06 ratios. For numerically higher gears like 3.69, it might be possible to install with a custom ring gear spacer and longer bolts, but AFAIK nobody has attempted this yet. Side note - I am not aware of any 3.07 ratio in 210mm size... 3.07 is a common 185mm gearset.
#208
Ah, so my fears have been confirmed.
It looks like the 3.06 is the one that I will be looking at, and with it the meter as well.
While the response of the 3.69 would be great, custom is too hard left!
p.s. Dont think anyone has tried a wavetrac lsd?
Best
Best
#209
Hi everyone,
Thanks.
Thanks.
#210
300D, 500E, E420
You can bolt in the factory Mercedes clutch-type LSD, but Quaife doesn't make anything for the 3.69 gears. You may be able to have a precision ring gear spacer machined to make the Quaife work but this would not be an optimal solution...
#211
OK, thanks. Where to get the factory Mercedes clutch-type LSD? Do you mean ASD?
#212
300D, 500E, E420
Any Mercedes dealer can order the LSD for you. The part number is on page 4 of this PDF file. Current price looks like approx $1065 EUR excluding VAT.
No, I do not mean ASD. Please read the rest of this thread for an answer to that question.
#213
$1065 + VAT looks like a quite friendly price to me. I was told $4,200 + VAT by my local MB dealership for the original ASR.
Are you saying all I need is to order this part no. 140-350-29-23?
The reason I started looking for a new dif. elsewhere was the old one has one Prop flange leaking (A 129 350 09 45) and MB cannot order a new part anymore ($350). They offered me a new dif for this incredible price. Hence I started looking after solutions and realized letting go the ASR for LSD might be the best mod ever..
#214
#215
300D, 500E, E420
Your 300CE-24 should be a 124.051 chassis, and should have a 210mm ASR diff, which would use LSD # 1403502923 with 3.69 gears (click here, enter part number to get pricing).
This is NOT a complete differential assembly! It is only the center section, the limited-slip unit / ring gear carrier, as seen in the attached photo. You would have to install this in your existing differential. Photos of the process are shown here.
If you have a leak, replace the seals. The flange should not need replacement unless there is a significant groove worn into the shaft from the old seal (which is highly unlikely). That ~$4k price is for a complete new or rebuilt differential assembly, and it wouldn't be LSD... Mercedes never offered ASR with LSD together. ASR is "electronic LSD". You can read more about ASR vs ASD function here, and LSD function here.
#216
My LSD with 2.82 gears is up for sale in the classifieds. Built from the ASD non-ASR differential from the 300SD. This will bolt right into a V8 car but if you have ASR, it will not function.
https://mbworld.org/forums/engine-pe...-82-gears.html
#217
300D, 500E, E420
FYI... the non-ASR diff is best for non-ASR cars. If you install this into an ASR car (like a 500E), you will not have either ASR or ABS functioning. The ABS diff has a single speed sensor at the pinion, the ASR diff has two speed sensors (one at each axle shaft). The two are not interchangeable.
It's a GREAT deal for someone with a non-ASR 400E though! I'd be all over this if it were an ASR housing (my 1995 E420 has ASR).
#219
I know Eric had one of his 400Es running 14.4 with stock gears and an open diff. If he still has that car, and is interested, I would ship it to him for no extra cost (I'll pay shipping) if he installs it, and reports his ETs. It would be cool to have a 4.2 break into 13s.
#222
I'm looking to get the CLK 430 differential (198mm, 2.87 rear) to 3.XX+
I don't have abs or asr installed. No computers or abs in the vehicle.
What are my options? Sounds like I can just get the ring and pinion 3.27 or 3.69 from the w124 with 210mm diffs, and swap that into my housing, correct?
What is the lsd option for 210mm, if no electronics need to function?
#223
1993 W124 300E 2.8
I would say W208 and W124 rear ends are not that easily interchangeable.
CLK 430 has 2.87 diff ratio.
Why not just get a diff from W208 320 (3.07) or 230 Kompressor (3.27)?
CLK 200 had a 3.46 or even 3.92 diff ratio.
Quaife offers a bolt-on TORSEN-type diff for your application.
#225
I need help with my W123 280CE rally diff
AMGDave,
I just finished reading all 9 pages. Respect and thank you.
Please correct me if im wrong or confirm that what i plan is doable.
I drive a W123 280CE with a 200D diff. (3,96 gear ratio)
I use it on trackdays :
I desperatly need LSD in my diff.
On peachparts forum I learned that 3 guys have build LSD diff in w123 casing using a W201 2.3 16V diff carrier, and a 5 mm spacer and longer bolts.
Attached you see pictures of the diff i purchased, its suppose to be from 86k miles W201 2.3 16V, with ASD.
Am I ok to start dismantling both diffs W123 200D diff (3,96 gear ratio) and W201 diff with asd ?
both diffs are around 14cm wide. but the w201 carrier seems a little wider, and inside of a w123 diff there seems to be not enough space, and Im affraid that the carrier position will be to much to one side , after we machine out the inside of the w123 diff.
I might be writing nonsense, i have information oveload,
I payed 200 USD for the diff.
Can I use W124 ASD diffs ? they come much cheaper ?
W201 is 185 i guess thats why i had to pay extra for a 16V diff, any compatbile W124 asd diffs i should be looking for ?
the peachparts thread is here :
http://www.peachparts.com/shopforum/...slip-diff.html
