blower motor ahhhhh
1993 Mercedes 300e 4-matic (m103 motor)
blower motor ahhhhh
ok so my room mates 88' 300e when he first got the car i was amazed at how well the motor worked. Today after a huge rainstorm in phoenix, the motor just stopped. When you push in the HVAC controls all I can hear is a vacuum leak from behind the glove box. No sound from the motor at all. i check all the fuses and even the external blower fuse. Anything i should check? Also in the even i have to change out the motor anyone have any directions on how to get to it?
1995 E320 SE, 162,000 Miles (Sold)
sorry dont have much experience with the blower motor not really sure what i'm looking at. I'll go tak eit apart right now, but what does the fuse itself look like. will it be marked?
1 Post
08 Lexus GS350 AWD. 08 Lexus RX350 AWD - wife's. 94 MBZ E320 - still have it.
With the car running and the heater in the "on" position try to slightly wiggle the ignition key. Sometimes the elecrical contact in the ignition switch goes bad and failes to provide the juice for the blower relay/motor.
http://www.mercedesshop.com/Wikka/W124BlowerMotor
I would double check the fuses. If you read voltage from one end of the fuse to the other (across the fuse), it's blown. 0 volts is a good fuse, or it means there's no power to it.
