adding power antenna switch
Old Mar 11, 2008 | 03:02 AM
docpaul's Avatar
1991 300E 63K miles in Ice Blue
My 91 300e does not have a switch for the power antenna. I much prefer to be able to control it instead of having it go up and down every time I start or shut off the car. I bought a panel with extra slot for the switch and wonder if anyone has wired one of these before?. Earlier and later years both had the switch but for some reason in 91 they decide not to use it...
Old Mar 11, 2008 | 11:30 AM
ZedStyle's Avatar
Youngtimer
i was going to do this as well, but i never listen to the radio so i just disconnected my antenna altogether. it should be very simple, just an in-line switch on the 'on' wire, i would think
Old Mar 11, 2008 | 03:50 PM
YNVDIZW124's Avatar
lots of cars
The radio has a power antenna lead so you can route that wire to a switch on the dash to turn it on or off. A switch like the ones on the early versions should work to control the height of it too? I would look at all the wires from the power antennna and see whicih one controls the motor. Follow the wires all the way to the console and add a switch there too.
Old Mar 11, 2008 | 06:14 PM
forcedawd's Avatar
W124, W220 S500 4matic, W140 S500, CLS55 AMG
Here is a pic of the earlier style plug that has the additional wires to control the height of the antenna with the dash switch -
The red/yellow wire should read 12v constant
The brown wire is ground
The solid blue wire should see 12v when the radio is turned on (remote)
The 2 additional wires are the blue/yellow and blue/green. These are the 2 wires that go to the dash switch. They alternate between 12v and ground depending on the switch position to determine antenna height.
Sam
Old Mar 12, 2008 | 03:15 AM
Geh's Avatar
Geh
2007 GL500, 2007 E280
My 89 260E Doesn't have a antenna switch Even though my Antenna motor is Routed atm
Old Mar 12, 2008 | 02:16 PM
docpaul's Avatar
thanks it should be easy
Sam and all,
You guys are the best. Thanks for the details should be easy...
