--What are these in My front Springs--
Old Mar 29, 2008 | 11:27 PM
berti_00's Avatar
2016 Cls63s AMG
Hey guys i've been looking at my front springs for a while and i couldent help but ask to why do they have some ALUMINUM looking things in between the springs? what are they?
here is just an example and the red is where those things are on?
i am woundering if i take them off will it lowr my front more?
Old Mar 30, 2008 | 12:58 AM
ZedStyle's Avatar
Youngtimer
i'm pretty sure you shouldn't have anything in-between your coils, or 'in' the spring anywhere... take pics! maybe someone left the plates of a spring compressor in there...!
Old Mar 30, 2008 | 02:27 AM
berti_00's Avatar
2016 Cls63s AMG
hmmmm could it be?
Old Mar 30, 2008 | 02:34 AM
ZedStyle's Avatar
Youngtimer
a picture speaks a thousand words!
Old Mar 30, 2008 | 02:39 AM
berti_00's Avatar
2016 Cls63s AMG
hey zed but i was doing some reseach and i found this
as you can see the compressor they couldent be left on there because they are thin not thick enought to reach coil to coil you know what i mean?
Old Mar 30, 2008 | 07:47 AM
fred1948's Avatar
2005 E320 CDI
Sounds like something like this: http://cgi.ebay.com/ebaymotors/Coil-...spagenameZWDVW
I have never used them but they were popular in the 60's when raising cars was popular. Sounds like they would put a lot of stress on the coils.
Old Mar 30, 2008 | 10:20 AM
ShanMan's Avatar
'95 E420 SE
two thoughts:
1) The compressor tool you show is not the correct one for our cars...it should look like this:
...and so you can see where the pressure plates could in fact get left in there...but not likely at all that they would still be there unless really pinched. If that were the case however, I would expect the car to sit a bit higher...equal to the thickness of the plates.
2) Seems to me that AMG spec'd spring compressor spacers similar to the ones shown in the other reply post. Presumably to keep things from rubbing under full suspension compression. This would not have any effect on static height of the car IMO.
Old Mar 30, 2008 | 12:57 PM
berti_00's Avatar
2016 Cls63s AMG
yes yes yes thats it.... thats whats in the front...
should i go ahead and take them off will it drop alot or not?
Old Mar 30, 2008 | 01:00 PM
ZedStyle's Avatar
Youngtimer
i can't think of any reason why those should be on there, other than someone wanted to raise the front. i would just take off your wheel and take them out...
Old Mar 30, 2008 | 01:08 PM
berti_00's Avatar
2016 Cls63s AMG
you think it will drop a bit? so i dont have to go through the hassel of friken doing the spring pads? what youthink?
Old Mar 30, 2008 | 02:20 PM
STLe320's Avatar
95 e320...sold the rest
well if their purpose is to raise the front end, then taking them off/out will obviously lower it. i'm not sure how much though...give it a try!
Old Mar 30, 2008 | 02:37 PM
berti_00's Avatar
2016 Cls63s AMG
yah lol am woundering too how much will i get slamed? scared now but am gone try and take them off anyways
Old Mar 30, 2008 | 06:47 PM
Bigpete123's Avatar
1990 300ce
be careful!
Old Mar 30, 2008 | 06:51 PM
berti_00's Avatar
2016 Cls63s AMG
Originally Posted by Bigpete123
be careful!
ohhh am not going to do it my self.... mechanic or something
Old Mar 30, 2008 | 07:19 PM
raymond g-'s Avatar
99 E320
I have to be in west seattle at 5 pm, but can try to swing over after 6 pm and
take a look if you want. it seems odd that the pancake clamps would still there
in that location and not have fallen off all this time. nothing is holding them in
there except for a .25" relief in the plates. (or meet you 1/2 way between
kirland and seattle)
Old Mar 30, 2008 | 07:22 PM
berti_00's Avatar
2016 Cls63s AMG
were do you want to meet me and thanks for offering the help man... and i dont think i can go to far out my front tires are PLAIN BALD like all gone... i have the tires but waiting for a buddy to see if he can put them on at his work or somthing....
Old Mar 31, 2008 | 01:56 AM
raymond g-'s Avatar
99 E320
I swung by and took a look underneath the car. It's a single, wedge shaped,
almost arrowhead design spacer which has contours in the middle approx the
diameter of the coil. I suggested jacking up the car so as to remove much of
the spring tension, then seeing if he can simply tap them from the opposite
(ie inside out) and drive it out.
I was in a rush doing errands. I meant to snap a photo and post for you guys
to see.
Later in the evening, I thought that if unloading the suspension wasn't sufficient
to pop the spacer out (though in my head, it should) another method would have
to be to remove the coil and 'thread' the spacer out.
Berti's goal is to try to lower it another .75". I didn't think removing this spacer
would be sufficient. He already has a #1 spring pad. So to make up .75"
he would need to run w/o spring pad, or cut the spring (it is already a lowering
spring, manuf unknown).
I've never seen a coil spring spacer of this design so unable to conclusively
advise how best to remove. Looks old school, JC Whitney-like solution.
Doesn't appear difficult....this, coming from someone who has his own spring
compressor. Hopefully, it'll just pop out after he jacks up the car.
Old Mar 31, 2008 | 02:53 AM
berti_00's Avatar
2016 Cls63s AMG
to see.
hey man thanks alot for stoping by.. i appriciate it,, anyways yeah i thought about it too and maybe if i take the pads off and sand them down like you said to a very thin layer plus take those spring spacers out maybe i can get like .50" or so wich will be fine enought i dont also want to loww since my bumper is really low too you know.... hopefully you can help me in one of these better weather days
good day
Old Mar 31, 2008 | 11:09 AM
ZedStyle's Avatar
Youngtimer
berti, don't be lazy! just jack up the car, pull off the wheel and see if you can get that thing out of the spring... worst that can happen is you'll fail and get someone else to do it... then you'll know if you need to play with the spring pads
Old Mar 31, 2008 | 01:17 PM
Bigpete123's Avatar
1990 300ce
Albert, when I saw your car I really didn't notice a height difference between the front and rear. Maybe I just didn't look carefully enough. But your car looked level to me!!
3/4" is a lot! Is the difference really that noticeable??
Old Mar 31, 2008 | 02:05 PM
berti_00's Avatar
2016 Cls63s AMG
noo its not actually that much but its just mee sometimes am an a$$ lol and want it to be perfect... but i just want a little bit more... am going to take the pads out in the front and just leave a very thin layer so the springs will have rubber contact and not metal to metal
Old Mar 31, 2008 | 04:46 PM
STLe320's Avatar
What do you think you'll use for pads then? I've heard a piece of hose?
Old Mar 31, 2008 | 08:16 PM
berti_00's Avatar
2016 Cls63s AMG
well what **raymond g-** suggested is that i take out the spring pads on the front and than sand them on the machine untill its soo thin that its jut a small layer of the spring pad just so it will be in contact whith the springs and not contact with metal to metal... so i'll get a some drop on that for sure and than maybe a litttle more ones i take those aluminum spacers on the springs as well and i'll be happy ....
Old Mar 31, 2008 | 10:18 PM
raymond g-'s Avatar
99 E320
i may have used the word 'shave' but sanding may not give the best results.
i'd use a coping or hacksaw blade with fine teeth. you're looking to cut the
puck down to a thickness which still give you drop...and cushion between the
top of the spring and spring perch. how thick that is will be up to you.
this was the thread i was trying to remember yesterday when i described
where someone grafted two pads together.
Old Mar 31, 2008 | 10:48 PM
berti_00's Avatar
2016 Cls63s AMG
haha yeah i was trying to find that word SHave but just didnt click on my head... but yah... soo just shave the pads on the top right? and what do you mean and the spring perches?
