Supercharging '87 300e
botom line is, it can be done... not easy, but it can be done.
home made kits an get away with a corect sized blower, a piggy-back setup, small intercooler and a rebuild head and tranny...
good luck, my friend, and take your time!
Cali
That is where a c36 AMG (m104 3.6) comes into play
all I have to do is find one... But from what I hear this engine should still bolt-up to my tranny and everything.
spmbass - since your car is either going to need a lot of work or be sold can you try out a high voltage coil?
Back on topic....
I install custom turbo kits on all types of cars, and there is no way around upgrading the fuel system. If you blow more air into the engine, you have to shoot more fuel in... simple as that. If you put a turbo or supercharger on an engine and don't compensate with extra fuel, you'll melt or break things... expensive things. The cheapest way on a 300E is with an AIC, but that's far from the best way. The best way is a custom stnadalone system like the megasquirt. Either one is a project for someone with ALOT of experience with forced induction.
Back on topic....
doesnt an increased coil power allow for you to increase the plug gap, giving a stronger spark and increasing fuel burning efficiency?
more air - more fuel! simple enough, yet dificult to manage... increased coil power is a a cheap 1'st stage solution. COP is the way to go, expensive but more eficient...
over the past two years, I've been reading a lot of horse ch^t, trying to setle on a solution to give my m103 (12v, I6, 188hp), 150-200hp more... with all the info gathered, I can summ the folowing:
stage 1:
Jetronic still on, twin turbo (small k04's), 8psi, small front mount cooler, 3 injectors with piggy-back (AEM, Apexi, Haltech, the sort), upgraded coil. output 300-350hp
stage 2:
Megasquirt (or Autronic, Haltech, AEM, etc.), with CDI, twin turbo (same k04's, or gt28's), 1bar, forged pistons, front mount cooler, upgraded gearbox, etc. (list is long). output 400-450hp
stage 3:
check Pumpish! Roman and his nordic fellas are crazy, and they really now theyre bizzz...
output ...
Before we start bench racing we need to know what kind of hp and how much money you guys are willing to spend. I'm sure there is a way to get more fuel out of the CIS system and we just need to find it. If money is not an option anything can be done but point is that we need to find ways to work with what we have.
once i hit about 3k rpm on the highway throttle response increases greatly
