New Radiator and Thermostat
1986 300E
Can anyone venture a guess on how big my repair bill will be for these? I had my 1986 300E towed to an independent shop yesterday after the radiator neck broke. I've only had the car a few weeks so I'm pretty new to Merc.
1993 400e
hey i noticed that your in the bay area norcal...so am i...i just replaced my t stat on my 93 400e...it wasnt that bad...i can do it for you for prolly cheaper....its not that hard. btw im a ase master tech...worked for a ford dealer for 3 years as a heavy duty diesel tech....lemme know...im from vallejo.
W124's
You can typically find the radiator online or in stores for about $160-400 depending on where you buy it.
Thermastats range anywhere from $30-100.
I recently did all this maintanence and the total bill from my sources alone for the parts only was close to $200.
1986 300E
1991 300E 63K miles in Ice Blue
quality parts for Benz
I just did the radiator, thermostat, and waterpump a couple of months ago.
BMA in Glendale is excellent for parts!! Ask for Yves, the owner, 888-262-3911
I paid $155 for a Nissens radiator as the OEM Behr was considerably more $$ and it was perfect fit. Thermostat Vvarnet for $9.50, pump Graf $155
Fast, friendly service from these guys, they are BMW specialist but can also get good deals on Benz OEM parts when necessary/ and if there is a mistake they make it right.
My opinion is that unless you are a skilled mechanic with tools don't try to change the pump yourself!! Radiator is a piece of cake and you don't even need a manual. Use the proper coolant for Benz.
