1994 E-320 Rear Headrests not working!Please help!!!
Old Oct 10, 2008 | 01:56 PM
uncandid's Avatar
1994 e-320
Unhappy 1994 E-320 Rear Headrests not working!Please help!!!
I have a 1994 E-320 and for some reason the rear headrest won't go down with the button on the dash like it used to. I can still go in the back seat and pull them up, but then i can't use the button on in the front to drop them down. Any ideas before I get robbed at the dealership? Thanks for any suggestions!
Old Oct 10, 2008 | 01:59 PM
berti_00's Avatar
2016 Cls63s AMG
sometimes you have to hold the button a bit
Old Oct 10, 2008 | 02:27 PM
uncandid's Avatar
1994 e-320
Thanks for the quick reply, i just tried holding it down for 45 seconds and nothing. Any other suggestions?
Old Oct 10, 2008 | 03:18 PM
YNVDIZW124's Avatar
lots of cars
Get a screwdriver and remove the two screws holding the panel on the back of the seat. You probably have some broken parts in there..
Old Oct 10, 2008 | 04:26 PM
uncandid's Avatar
1994 e-320
Thanks, I'll try that today and let you know...thanks again
Old Oct 10, 2008 | 10:44 PM
rivcal4life's Avatar
92 500e, 95 E34 525I Touring
Wait are you talking about the front seats Albert?
YNVDIZW124, not bertii.
Old Oct 11, 2008 | 03:09 PM
YNVDIZW124's Avatar
lots of cars
OPPPS, my bad . Those are vacuum operated. Check the fuse first and if that doesn't work remove the bottom seat by pulling on the two tabs on the bottom of the seat. There should be a vacuum pump thing under the seat. You can also make them go down manually in the trunk.
btw, my name is Abe.
Old Oct 11, 2008 | 05:15 PM
Eek..Sorry. I had a feeling when I posted that I was wrong. Not sure why I thought it was albert. Abe, got it.
Old Nov 11, 2008 | 01:50 PM
benz2javelin's Avatar
1986 mercedes 300DT
same problem.
i am having the same problem and i was wondering how exactly you manually release the rear headrests in the trunk.
Old Nov 13, 2008 | 11:16 AM
Jim's500E's Avatar
Smile
Does the car have the rear sunshade?...if so, the sunshade has to be completely down and recessed for the headrests to go down...you may have to push it into the slot. When they age they don't fully retract sometimes.
There's a vacuum switch back there also that's cheap that also is what it could be.
