Ouch
Old Oct 26, 2008 | 10:37 PM
mr_e320's Avatar
1994 E320
Ouch
So I just found out that my E320 needs a new head gasket. The part is relatively inexpensive but with labor, ect the bill comes out to $1500....
This would be fine if I weren’t still in high school. Are there any other, less expensive solutions to this problem?
Old Oct 26, 2008 | 11:16 PM
childofjuly's Avatar
1995 E 420
man for that price I would try to replace it myself.. it can't be that hard.
Old Oct 26, 2008 | 11:24 PM
battlecat714's Avatar
a TVR Cerbera Speed Twelve
Ouch, um, where are you located?
Old Oct 27, 2008 | 02:13 AM
ZorroAMG's Avatar
Enzo, my Benzo
You can machine the heads, replace the valve guides AND replace the head gasket? That's what's done on our cars during a proper head gasket r&r...10hrs labor. I know MY time is worth more than that...
Old Oct 27, 2008 | 03:59 AM
1995 E 420
why would you replace the valve guides when there is nothing wrong with them? valve guides are probably the least likely thing to go wrong in the valve train..they don't usually need replacement or grind down unless there is a dropped or bent valve... if you're going to replace your valve guides you be better off replacing with all new valves, springs, retainer, and cotter. there's no point to replace the valve guides and put all the old valve train back in.. that be a truly waste of effort. Zorro i think you are referring to a full head Job. (valves, guides, springs, head resurfaced , valve seat cut, ect) If so than everything you just mention are right on target. this could be a shade tree weekend job if you are mechanical inclined, expect 10 plus more hours for sure.. and if you are in high school and have no ends I would consider it. Just make sure you have good references! worst case you'll end up taking it to someone, which you'll have to do anyways if you don't try it yourself. so nothing to lose while you're learning about your car....i love my free time but @ $150/hour... ($1500 for the 10 hour job) ..somebody show me my time card, i'm clocking in early!
Old Oct 27, 2008 | 06:41 AM
fred1948's Avatar
2005 E320 CDI
If the wiring harness has not been replaced yet then you can count on having to replace the wiring harness as well. The harness is about $800 just for the part.
Old Oct 27, 2008 | 02:54 PM
mr_e320's Avatar
1994 E320
way out of my league right now
also...located in alabama
Old Oct 27, 2008 | 03:48 PM
ZedStyle's Avatar
Youngtimer
i think you're done... ask your parents for some loot, or try and sell it and get a more high school budget-friendly car
Old Oct 27, 2008 | 04:31 PM
ZorroAMG's Avatar
Enzo, my Benzo
First you SHOULD machine the head to make sure the gasket fits, otherwise it's a waste of time.
Second, you are right, the other stuff is for the full job, I had it done on my M103 2 years ago....the head tech at the dealer that worked on it is my buddy so I got a tiny break and a great job...I just know it was a lot of work....work that makes sense to do while the top end was already apart.
Old Oct 27, 2008 | 05:13 PM
1995 E 420
actually if the head is not warped a quick gasket will be adequate. machine and decking jobs are more desired when doing a full rebuild or building a high compression/performance engine. usually after a full head rebuild you'll bump the compression ratio up a little due to the extra material lost during resurfacing of the head. it shouldn't be a big problem here but for me it was between either running pump or race gas. ( I went with a thicker custom gasket to run pump gas) but I couldnt have agreed with you more on replacing everything! If youre going to spend the time and money, do a FULL over haul!!
Old Oct 27, 2008 | 06:30 PM
fred1948's Avatar
2005 E320 CDI
What part of Alabama are you in. I am in Huntsville.
Old Oct 27, 2008 | 06:36 PM
ZorroAMG's Avatar
Enzo, my Benzo
Really? I always thought you needed to machine, seeing as it's sometimes hard to tell if the head is warped or not...you know...better safe than sorry?
Thanks for the info!
Old Oct 27, 2008 | 06:56 PM
190E 16V's Avatar
1987 560SL
Thumbs up
I agree, Mark - you sure don't want to do a job like this twice.
With my previous American and Brit cars, when I replaced the head gaskets, I just laid a steel scale across the head to check for straightness.
I did a couple like that, without shaving the head, and crossed my fingers. Worked out fine.
That being said, I did it because I was cash-strapped, and I got lucky.
From all that I've read about the prevelance of W124 head gasket woes, you need everything going for you, and planing the head is highly recommended on these cars.
That's my 2 cents, anyway.
Old Oct 27, 2008 | 07:18 PM
1995 E 420
totally agree with doing it right! thats what I'm about too.. but there are pretty easy ways to tell if your heads are warped or not.. you can run a compression test.. if you have no or bad compression on all cylinders that could mean your heads are warped.. and if you have all good except for 1 or 2 than its a gasket.. or you can do the method 190E did with a straight edge from corner to corner and a feeler gauge.. not hard just time consuming...
Old Oct 27, 2008 | 07:34 PM
190E 16V's Avatar
1987 560SL
Old Oct 27, 2008 | 10:19 PM
mr_e320's Avatar
1994 E320
Alabaster...near Pelham
Old Oct 27, 2008 | 10:23 PM
mr_e320's Avatar
1994 E320
Dunno if my parents will help but hopefully my uncle will... he's a major benz guy so he understands. additionally i'd hate to get rid of it.....i love that car
