1st Gear downshift help mod? vacuum psi idle?
Second is whats the psi vacuum at idle. Trying to find if I have a vacuum leak?
ps sorry my space bar and keyboard broke on laptop
Vacuum at idle in neutral with no load should be around 12 inch of hg or better.
I will see if I can find the list in my books.
Also the cable you turn to make the tranny shift ahrder is that the cable that is conected to the throttle
?? Can I take the down shift button under the peddle and move it so I can hit it??
No need to move the down shift switch from under the pedal; just add another switch in parallel. I have not done this but it is a common mod.
