--Antilock/abs light--??
Old Nov 8, 2008 | 11:16 PM
berti_00's Avatar
2016 Cls63s AMG
hey guys something weird goin on with the abs system that i dont know what it is... when i come to a very slow stop or like slow down on bumps you can hear this grinding sound like the breaks or not working or something? and than after a while my light comes on and the funny part is that when the light is on THe breaks dont make that noise?
is my abs system bad?
there is a guy parting his w124 around me here and he said i can have his abs system for 30bux?
what could be wrong here?
Old Nov 8, 2008 | 11:26 PM
rivcal4life's Avatar
92 500e, 95 E34 525I Touring
Youre brake pads are wearing down spaz.
Just replace the pads. <3
Old Nov 8, 2008 | 11:31 PM
berti_00's Avatar
2016 Cls63s AMG
they are brand new and so are the rotors
Old Nov 9, 2008 | 12:18 AM
190E 16V's Avatar
1987 560SL
Cool
Who did your brakes?
When the pads are replaced, you should replace the ABS sensors on the calipers too.
These are very cheap and can be swapped out easily.
Sometimes re-using the old ones does not work - they're a bit delicate and easily damaged during brake pad replacement.
Check this out first OR if you paid someone for the brakejob, take the car back there.
Old Nov 9, 2008 | 12:48 AM
berti_00's Avatar
2016 Cls63s AMG
the sensors are new as well....... the thing is that it did this before i had the new breaks and rotors and all too but not as offten but i guess it could be the abs unit pump or w.e it is.
Old Nov 9, 2008 | 12:50 AM
ohlord's Avatar
Front
brakes.Wear sensors,about 2bucks.
abs speed sensor is on the rear diff.
Did they or you replace the wear sensors?
check it out,before they check you out
Old Nov 9, 2008 | 12:52 AM
I thought they were. I agree with 190E though. It is most likely the sensors. If the shop reused your old sensors, they may just be beginning to wear in. A lot of aftermarket pads do not have a specific place to mount the sensor. In my case, I opted to remove them all together. I pay attention to my car enough to know when my pads need to be replaced without needing a light to tell me every time, and it saves me around 6 bucks every cycle. The light is off by default, so once theyre disconnected it shouldnt some back on unless you have any real issues.
Old Nov 9, 2008 | 12:54 AM
Never mind then. Its worth a try to look though, considering, as I said, that a lot of pads do not have a real place to mount the sensors.
Old Nov 9, 2008 | 01:03 AM
berti_00's Avatar
2016 Cls63s AMG
yah i had the break light on because the sensors were bad so i got bran new sensors and they were put on and the break light went off of course but my ANTILOCK light comes... my break system is all new the problem here is somthing with the ABS
Old Nov 9, 2008 | 05:25 AM
Oh well, I tried man. Good luck with whatever it is man. Hopefully its not too expensive.
