Mb 2.5d 20v superturbo projekt
#101
w124
#103
w124
#105
w124
New valve size are, exhaust 28mm = 1.1" and intake is 30.5mm = 1.2".
I work on car parts dealer so i bought all parts from my workplace.
Also come s stiffer valve spring and retainers. 604, 605 and 606 stock valve spring are very lousy.
I go now two turbo system. Now come s one little and one big turbo
Holset Hy35 on the low end and Hx50 on high end
![Wootrock](https://mbworld.org/forums/images/smilies/wootrock.gif)
Like this
![](http://www.dieselplace.com/forum/uploads/twin_turbo.jpg)
I have now tested the engine at 3bar boost and works fine at Holset Super Hx40
My engine has N/A engine camshaft. Those has more lift and degrees than turbo camshafts. We make new ones those N/A camshafts. More lift and degrees.
#106
1 Post
95' AMG SeeThreeSix
Wow jeemu! Loving the idea of a DUAL turbo setup, maybe take a pic of the old valves and the new next to eachother for comparison? Machine work on the valve seats looks fabulous. Keep us updated! ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
DO you think you will eventually put this beast on a dyno? I'm interested in the numbers 3bar would put out
![devil](https://mbworld.org/forums/images/smilies/devil.gif)
#107
w124
DO you think you will eventually put this beast on a dyno? I'm interested in the numbers 3bar would put out![devil](https://mbworld.org/forums/images/smilies/devil.gif)
This is dynod two times. First setup it give 380hp/580nm and second time 445hp/626nm. Hope it gives next time over 500hp
#109
w124
Now i have Holset Hy35 on and it spool very fast, but not good on high boost. Maybe 1.5bar and 6mm injection pump it works fine ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Any way. Hy35 get a friend on. Next month comes Master Power. Kompressor 64mm and turbine 68,5mm
#110
1995 E300d
the hy35
I was thinking of that set up when does the boost come on and when does it fall off? I am only looking to make 250-300 hp with my 95 NA606. Also doesn't the 606 come with the 6mm elements in the stock pump?
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
#111
w124
If i drive stable 3000rpm i have 0.3bar boost
I took my new cylinder head on flow measuring.
Exhaust in pretty good but intake is behind it. We found what there is trouble and will wix it
Imukanava/modifioitu= Intake/modifield
Pakokanava/modifioitu=Exhaust/modifield
Link to measuring pic http://jeemu.kuvat.fi/kuvat/Hammer/Kuva0627.jpg/full
I have pretty good feeling at i get over fivehundred on five cylinder
#113
w124
#114
W203 C32 AMG, W124 E300D
#115
w124
#120
w124
Hello. Turbo rpm sensor installed on little turbo
![](http://jeemu.kuvat.fi/kuvat/Hammer/turbo_rpm_sensor2.jpg/full)
And rest photos http://jeemu.kuvat.fi/kuvat/Hammer/
#122
w124
