Check Engine light when car is off?
Old Feb 6, 2009 | 02:49 PM
ps2cho's Avatar
E
Is this normal? I got into the car this morning and the check engine light was on....This is without the key in the ignition. I drove it to work and the light went off as I started the car.
...Just got home and this time the light was on all the time I was driving. The diagnostic light bleeps 5 times which I hear means the O2 sensor...(I replaced it less than 10k miles ago??)
Should the light be on all the time even when the key is off?
Old Feb 8, 2009 | 09:02 PM
Arnie's Avatar
08 Lexus GS350 AWD. 08 Lexus RX350 AWD - wife's. 94 MBZ E320 - still have it.
No lights should be on with the ignition off. Carefully check all the fuses. You won't believe the wierdest things a hairline crack in a fuse could cause on an older Benz.
Old Feb 9, 2009 | 02:43 AM
ps2cho's Avatar
E
I had someone tell me that is a common OVP fault...I did replace mine about 20k miles ago.
I unplugged the battery terminal to reset the codes...and it went away....That was 2 days ago and no check engine light yet or codes...
If it happens again I'll go ahead and buy another OVP. I need one for my backup anyway as they are such a consumable item and can cause havok amongst multiple things on this engine.
I'll go swap out all my fuses out for good measure as I have a ton of new ones lying around from a "box of parts" I bought a long time ago.
