18" AMG Wheels
Old Feb 6, 2009 | 09:18 PM
ascates's Avatar
1988 300CE
18" AMG Wheels
Hey guys, I wanted to know if you recognize what Amg wheels these are & will they fit a W124? They look like they might be from an S-class but i'm unsure.
Old Feb 6, 2009 | 09:34 PM
rivcal4life's Avatar
92 500e, 95 E34 525I Touring
Should fit pending tire size..
Old Feb 6, 2009 | 09:47 PM
Springbok's Avatar
1991 MB 300CE, 2007 MB CLK550, 2007 MB R500.
I bought some 18" AMG Wheels and the offset and widths were way to huge, although 18" diametre should fit. What is the tire size?
Old Feb 6, 2009 | 09:55 PM
These are not the same as your CLS wheels. Im not sure what car theyre off of, but a friend of mine had the same wheels mounted on his coupe without issue.
Old Feb 6, 2009 | 10:01 PM
ascates's Avatar
1988 300CE
I don't know the tire size. I'm looking to buy them from someone. I will email him to get the full specs.
Old Feb 6, 2009 | 10:06 PM
Tires sizes Im sure will be enough, but if you can get him to check the offsets, then we can tell you with absolute certainty.
Old Feb 6, 2009 | 11:54 PM
ascates's Avatar
1988 300CE
What about these? came off a 2003 S55 AMG 18x8.5 & 18x9.5. Tires are Bridgeston Potenza 245/45/18 (fronts) and Bridgestone Potenza 265/40/18 which I will change if I get them. Dont have the offset listed.
Old Feb 7, 2009 | 02:48 AM
I do not think those will fit. Most likely too wide for how tall they will be.
I could be wrong though...
Old Feb 7, 2009 | 11:19 AM
STLe320's Avatar
95 e320...sold the rest
The fronts would fit
Old Feb 7, 2009 | 12:34 PM
Quicksilver500's Avatar
1992 Mercedes-Benz 500E
Too tall and rears are too wide. C, CLK, SLK, E run different OD wheel/tire package than S, CL, SL...
Use this guys to figure out right tire size
http://www.miata.net/garage/tirecalc.html
Old Feb 7, 2009 | 03:30 PM
ascates's Avatar
1988 300CE
Ok guys. I found out for the first set of wheels that are chrome that the wheels have offset ET44 and 255/40/18. The rears have 275's on them but i'll change the tires & I believe ET is 46. So could i make these work? I'm not lowered
Old Feb 7, 2009 | 03:50 PM
Wow my bad man. There is no way those are going to fit. My friend has the same stlye with MUCH skinnier tires. 255 is way too wide for the front, and 275 is WWAAYYY too wide for the rears...
Old Feb 7, 2009 | 04:00 PM
ascates's Avatar
1988 300CE
Ok. But my question is will they fit if i change the tires down to a 245 in the front & 255 in the rear? like i said i can change the tires.
Old Feb 7, 2009 | 04:33 PM
Thats gonna be a dangerous stretch, and still may be too wide. I run 225/45 on 17" rims and I scrape just a little tiny bit on driveways. An extra 20mm on another inch of height seems unlikely too fit to me.
Old Feb 7, 2009 | 09:58 PM
ascates's Avatar
1988 300CE
I've seen quite a few w124s on the board run 8.5-9.5" and they are lowered. I have an 88 300ce if that helps any.
Old Feb 7, 2009 | 10:19 PM
berti_00's Avatar
2016 Cls63s AMG
i have 18x9;s alla round ET 35 225/40/18
and its slamed
Old Feb 8, 2009 | 06:17 PM
225 in the front is fine. 245 is cutting very close. Especially if its stretched onto the wheel.
255 in the rear should be fine with the right offset and rolled fenders.
