low coolant light intermittent & dim but good coolant level
Old 03-14-2009, 12:15 PM
idkmybffcms's Avatar
400E
Just topped off the coolant, lights still on. Dim and intermittent. Any ideas?
Old 03-25-2009, 06:17 PM
beekster's Avatar
1992 400E (180K miles)
Same thing happened to my 400E. I had very small coolant leak at the switch that was shorting the wires. Barely noticeable. I just replaced the coolant level switch and the light went away.
Old 03-26-2009, 06:23 AM
ksing44's Avatar
2010 VW Golf TDI
I unplugged the the wire that goes to the bottom of the reservoir and that got rid of the light for me. I guess I should replace the coolant level switch in the bottom of the reservoir, but unplugging worked fine.
Old 03-26-2009, 09:55 AM
CDP
CDP's Avatar
W124's
lol I have this problem too but I just unplugged the light like the rest of you.
Old 03-26-2009, 05:22 PM
ZorroAMG's Avatar
Enzo, my Benzo
It's the sensor malfunctioning....replace it or unplug it and never know where your coolant level is....
Old 03-26-2009, 06:23 PM
kwontumspeed's Avatar
93 500e<P>94 E320T "Sportline"<P>90 FJ62
Advising him to unplug it as we are approaching warm weather?
Malfunctioning sensor. Replace it.
Old 03-26-2009, 06:26 PM
YNVDIZW124's Avatar
lots of cars
Your temp gauge is going to tell the story more than a low coolant light. I don't know about you guys but i check all the fluids on my car every 2-3 weeks.
Old 08-09-2009, 02:23 AM
batangx's Avatar
1989 Mercedes 260E
did the same thing.
it's not really relevant to me anyways, cause I have a habit of checking everything every 3 - 4 days under the hood... much more frequently even on weeks without something better to do..
Old 08-09-2009, 08:01 AM
ksing44's Avatar
2010 VW Golf TDI
Exactly
Me too
I will get the thing fixed one of these days, but it isn't a priority because of the reasons above. I am planning to do it when I do the wiring harness, but I'm not doing the harness until I have to do the head gasket and front timing cover. So far my oil leak is so minimal it isn't necessary and I think my "cool harness" conversion may be helping to extend the life of my leaky head gasket. I think it must help to keep the engine temp below 95 degrees C, instead of 105 degrees C.
Old 08-09-2009, 06:31 PM
ZorroAMG's Avatar
Enzo, my Benzo
Read my FULL post instead of the words you WANTED to read lol.
Quick Reply: low coolant light intermittent & dim but good coolant level
