Looking for a DIY for removing distributor and adjustments
Old Apr 5, 2009 | 03:54 AM
epowers777's Avatar
85 euro w124 300d non turbo black on black......coming soon hx35 turbo intercooler
Looking for a DIY for removing fuel distributor and adjustments
Im looking for a DIY for for removing the fuel distributor and a DIY for adjusting the fuel and measuring everything with a multimeter. If you could help me out that would be great full
Also the fuel distributor has blue paint pen writing on it. Does that mean its has been rebuilt or is that how they came stock?
Old Apr 5, 2009 | 04:24 PM
epowers777's Avatar
Anyone???
Old Apr 6, 2009 | 12:33 AM
pifcat2's Avatar
300TE / 300E / 300CE
There's lot's of searchable info on this board, but you should start with the factory CD. The blue writing may indicate it's used from a wrecking yard.
Old Sep 3, 2009 | 11:01 PM
Jason.Ly's Avatar
1988 300E
I'd like to know as well. I replaced mine today and the car did not want to start after about 10 cranks.
Old Sep 4, 2009 | 01:11 AM
ps2cho's Avatar
E
Fuel dist? Unscrew all the fuel lines and there should be 3/4 bolts holding her down...that's it!
As for adjustment, it cannot be adjusted other than the EHA. You will need a CIS fuel pressure tester (or a generic with the CIS adapter). Go onto my FAQ thread and there's a link to the FSM with all the specs you need.
The only thing you can adjust is the lower chamber pressure via the EHA.
^ Jason, check that the seal was correctly installed...If it was...I think its probably a bad one. I don't see any other reason why the car wouldn't start assuming it was fine with an alternative FD. Even with the EHA plug disconnected
Old Sep 5, 2009 | 01:48 AM
Jason.Ly's Avatar
1988 300E
Thanks for responding. Do you mean the seal on the underside of the fuel distributor? If it's that black rubber ring, it looked fine. I bought my unit from eBay. It came with an EHA attached to it. I'm thinking the next thing to do is to swap out my EHA with the one that came attached to the newer fuel distributor.
