Engine stalled at traffic lights and stop signs
Idle is controlled by whatever fuel injection/management system you have. Mine's KE-Jetronic with a 'mechanical' MAF, yours may be later with the HFM management and a 'hot wire' MAF.
Either way, tweaking idle speed with the throttle cable confuses everything as it opens the butterfly valve and allows air through. There are idle control valves to do that. The management electronics will be utterly baffled by these tactics. I know this because a young MB specialist tried the same thing on mine when I complained of stalling.
The ONLY answer is to find the root cause of the stalling problem. With mine, it was a cheap rotor arm but I suspect yours doesn't have one. Assuming you'r is the later HFM system, I cannot say more but there are loads of posts here and elsewhere that address this.
All the best.
RayH
All the best.
RayH
I bought this car off an enthusiast and Merc parts dealer who had replaced all the HT leads, alternator etc very recently and he reckons the stall is happening because of a vacuum leak so I’ve got our super hero mobile mechanic coming to check that out in a few days time.
In the mean time I’m going to have a look for that fuse, if that’s all the problem is I’ll be a happy chap indeed!
I'm sure its just the OVP. Get that changed first before paying him any money.
I took the car out for a spin after putting the battery back in and it didn't stall once, as is the nature of an intermittent fault!
Someone please correct me if this is wrong...
He says I need to get a hole in the exhaust fixed before any CO2 problems can be diagnosed, so it's going to an independent Merc specialist tomorrow.
Im thinking its either OVP or Idle Control Valve...About to take a look when the weather clears
Oh, I'm writing this up on my blog now! -
http://lawsie.blogspot.com/2009/11/m...n-slowing.html
I took the car for a spin to see if it would still stall. I held the brakes on corners, held the brakes at traffic lights and generally did everything I could to make it stall and it didn’t. I was feeling cautiously optimistic, and decided to go to our local farm shop to buy some gourmet mayonnaise (I tell you this, because sometimes details are important) and had to hold the brakes for an age waiting to turn into the entrance. Shudder, poot, the engine stalled.
I gave up on buying Mayo and headed home. My optimistic side is trying to tell me that the stalling problem wasn’t as bad, but my pessimistic side is telling me that if the Mercedes specialists can’t fix this problem on Monday then I may have to sell the car. I’ve only had it two weeks and have only done 115 miles, and 100 of those were the drive from where I bought it to my home!
The good news.
The idle circuit air hose was badly split so they taped it up and ordered me a new one, cost is just £12! This will probably almost entirely eradicate the stalling problem. They noted on the diagnosis report that the OVP unit had been replaced, so I feel kinda like I did the right thing in replacing it.
The bad news.
The exhaust manifold is cracked and the oxygen sensor has become one with the rust therein. The catalytic converter is also shagged (my word, not theirs). So there’s air rushing in where air ought not to be rushing in, and the engine is getting all confused and running far too rich (hence the petrol smell I described earlier). The catalytic converter is contributing to the problem by kinda suffocating the engine, thereby twisting the knife that cases the stall. A replacement oxygen sensor will cost about £136.00 (not too bad), a new catalytic converter will cost £1162.00 (oh mercy).
The weird news.
The idle circuit air hose will be fixed within the week, and should almost entirely eradicate the stalling problem, in fact it’s already FAR improved with the Heath Robinson repair they put in place today.
If I’m happy with the performance of the car after the hose has been replaced then fine. If it’s still an issue then they’ll replace the oxygen sensor, mig weld up the holes in the manifold and remove the catalytic converter entirely – it turns out cars as old as mine don’t legally need one! So I’ll feel a little bad that my car is chucking out some nasties into the atmosphere, but that will be nicely balanced by the fact that I’m keeping an old car on the road! Keeping an old car going (to a certain extent) is surely better than buying a brand new car? Replacing the catalytic convertor is quite simply never going to happen, in fact if I was forced by law to replace it I would have to scrap the car as I can’t afford it!
RayH
Try:
www.mb-parts-teile.com
www.speed-autoteile.com
euromercmercedesparts.co.uk
Thanks as always you lot!
When I took the car in to have the new idle circuit air hose fixed the garage informed me that they’d found a non-Merc catalytic converter for £120. The car does drive better with the new hose but once I’ve started stalling I know the rest of my journey may take ‘some time’.
So I’m going to clear out the remainder of my non-existent W124 budget and buy a new cat £120 (US$200), a new O2 sensor (about the same price) and then pay the garage a few hours labour (at a very reasonable £60 an hour) to fit the parts and weld shut the hole in the manifold.
So fingers crossed this will fix the problem, because if it doesn’t I’m going to be driving this car until the MOT runs out in November then I’ll have to scrap it!
I saved up £500 to get the o2 sensor and the catalytic converter fixed. The split in the manifold also needed sealing up and the garage was also going to attend to that.
I woke up extra early to get the car down the garage, ‘this is the day’ I thought. I cheerfully mused to myself that when all the work was done by the end of today I would have a lovely car that I would keep for years.
With a song in my heart I turned the key in the ignition; well at least I tried to. The key wouldn’t budge and in my attempts to turn it I managed to lock the steering. No amount of gentle jiggling would free the ignition or the steering column so the garage sent out a professional key jiggler but he agreed things were looking grim.
So in addition to the o2 sensor, the catalytic converter and the welding on the manifold I was now in need of a new ignition system, steering lock and steering column parts. Even if I used pattern parts this would add about £350 to the current expected bill of up to £500, this brings me to a total of £850, which if you’ve been following this sorry tale is more than I paid for the car in the first place. So the end has come, the garage are going to recover my car to their premises and rape it off anything valuable in lieu of their bill for today’s work.
So I owned my 230te for thirty days and drove it about eight times. I’m feeling so screwed I limp a little when I walk and my wallet hurts so bad I can’t sit down without wincing. I haven’t owned a car for a year and a half and then once I had saved up the cash to buy one I just pissed £800 (US$1400) down a big black hole.
I’m done, I can’t afford another car, and considering I’m an IT consultant that has to go on call out this is not what I would call a happy ending.
I took a chance before getting rid of her that the problem could be bad gas. The tank was 1/8 full when the problem first surfaced. In the old days before computer controlled cars, my first thought would have been water in the gas or some kind of contamination. I added new gas to about 3/4 tank and the problem was still there.
As a last ditch effort, I got some Octane Boost and put that in the tank. The surging/stalling improved significantly and infrequently. I read an article about how Ethanol mixed gasoline can cause problems for cars and especially older cars and very much for old cars that aren't driven much. The article said that Ethanol gas is only good for 60-90 days.
I only drive my 300e once or twice a week for short hops. The gas in my tank was at least 60 days old. I guess I was a prime candidate for Ethanol-related performance problems.
I put some Sta-Bil in the tank and the surging/stalling problem went away pretty much right a way. I drove it for 50 miles or so through stop and go traffic and the surging/stalling disappeaared. I have subsequently added 3 ounces of Lucas Ethanol Treatment to my tank. I drove 60 miles today in all driving conditions and she never acted up. No surging or stalling and a consistent power band that I've always loved.
Perhaps the simplest (and least expensive) solutions are the best solutions!
I was suspect wiring issues, but after i taped up cam actuator and MAF hardness, still do the same thing. Checked T/B, it's super clean, even adjusted idel to 1200rpm, still do wont help.
We dont have MB OBD1 cable on our shop scaner, what i can do now is just diagnosis from every basic theories. I'll check if there is vaccum hose leak causing EGR working all the time or EGR stuck open. Then check spark plugs and coil tomorrow.
Any body experienced samilar condition or might have some ideas?
