93 300SD or a 97 E 300D
Old Apr 23, 2009 | 07:07 PM
Krafcik's Avatar
Acura
I'm looking at the two cars listed above.
I keep reading that the 93 is one of the last over engineered Mercedes. which to me implies that it is a better built car then the 97.
Is this true?
List price is 2k difference - although i'm sure i could talk them bother down (6k for the 93 and 8k for the 97).
93 has 50k more miles.
Is that enough info for you guys to help me?
Thanks,
Chris
Old Apr 23, 2009 | 09:24 PM
Actros617's Avatar
E320 300SD 300SDL
1993 300SD = head cracker and rod bender, if the engine the crank shaft and cylinder head has not been replaced, great car lots of power smooth and its an S class so its HUGE and TURBOCHARGED!
1997 E300D even more power good gas mileage, reliable, smaller and TURBOCHARGED
Old Apr 23, 2009 | 09:31 PM
YNVDIZW124's Avatar
lots of cars
Get the w210....
Old Apr 23, 2009 | 09:38 PM
Krafcik's Avatar
Acura
What about a 95 S 350?
Old Apr 23, 2009 | 10:45 PM
TMAllison's Avatar
09' E320
All W140 diesels got the rod bender 3.5L engine. Thought to be the worst engine MB made. There was a replacement crate motor made in very late 95 that was "thought" to have fixed the rod problem. Regardless, it is an expensive chassis to maintain and it computers are +16 years old. It won't get cheaper to own......
The 97 has th 606.912 NON turbocharged engine. Very relialbe but also slow off the line. Drives nice but wont win a race unless lined up against a NA 300D or 240D. Was the first year of the 722.6 electronic 5 spd trans. Has some probs with trans seals and conductor plates. If it was well maintain the harness seal should at elast have been replaced. That said, its a nice car.
$8k is prob too much unless it only has 100k miles. Be patient and look for a 98-99 turbo'd W210 for the same cost.
Old Apr 23, 2009 | 10:47 PM
Krafcik's Avatar
Acura
What about moving down to an 80's 300d?
Old Apr 24, 2009 | 02:21 AM
ps2cho's Avatar
E
If you can find one in nice condition with relatively low miles....it will run forever. They are pretty sought after though...so don't expect a bargain.
Old Apr 24, 2009 | 12:38 PM
JustPete's Avatar
CLS55 AMG 030
We did the block replacement in my '92 and almost 100K miles later she runs smoke free and better than new. Pulls like a V8.
Not sure if the fix worked for others but it definitely worked on mine IMO.
I even modified the turbo to spool up sooner so she pulls much faster than most. Runs completely smoke free no matter how hard you stomp on her.
Old Apr 24, 2009 | 02:58 PM
Actros617's Avatar
E320 300SD 300SDL
Go for the W126 300SD or W126 300SDL or W124 300D W201 190D
W126 300SD Comfortable smooth and big have mild sport's car like handling and the bullet proof engine good gas mileage
W126 300SDL Bigger than the 300SD fast smooth mild sport like car handling very good gas mileage, WARNING Potential cylinder head crack to learn more Wikipeda OM603
W124 300D Smaller the fastest diesel in the 80's, Very agile have the same head crack problem VERY GOOD GAS MILEAGE
W124 2.5 Turbo, less powerful, fast, sounds cooler, very reliable, no cylinder head crack problem and the BEST GAS MILEAGE....
W201 2.5 Turbo, Very fast, ROCKET ACCELERATION (faster than the W124 2.5 Turbo) super reliable very small superior handling superior MPG
W201 2.5 N/A less powerful able to beat a 300SD very good MPG
W201 2.2 Even less power but is able to beat a 240D , CRAZY MPG, careful for warped cylinder due to overheating for more info wikipedia OM601
if you going for a 80's diesel benz, go for one of these
