Grilles?
Old May 7, 2009 | 01:37 PM
Ratbike1's Avatar
2011 C300 4Matic
Grilles?
What are your favorite grilles for the 94-95s?
I'd like to change it, but am unsure which one to go with.
Pics would be even better!
Old May 7, 2009 | 01:49 PM
ZedStyle's Avatar
Youngtimer
https://mbworld.org/forums/e-class-w...l-87-w124.html
Old May 7, 2009 | 01:51 PM
Ratbike1's Avatar
2011 C300 4Matic
Thanks but those are for the older version, no?
Old May 7, 2009 | 02:11 PM
ZedStyle's Avatar
Youngtimer
did you look at the pictures in the thread
Old May 7, 2009 | 02:14 PM
ps2cho's Avatar
E
I use the SL600 grill. Its a little "plasticy" but it looks 10x better than the stock grey one for the 260E. If you decide to get this, or in fact any other that is made of plastic, make sure to secure it down tight or every time you pop/shut the hood it sounds horribly cheap.
Old May 7, 2009 | 02:15 PM
Ratbike1's Avatar
2011 C300 4Matic
Yes, I did.
Are the SL style grilles sacreligious on our cars?
Old May 7, 2009 | 02:17 PM
Ratbike1's Avatar
2011 C300 4Matic
That was the grille I was leaning towards, actually. Thanks for the tip! Is there a trick to securing them correctly?
Old May 7, 2009 | 02:34 PM
ps2cho's Avatar
E
I ended up cutting a small piece of cardboard and that did the trick. Its because sometimes they don't quite fit with the metal clips from the stock setup as the new grill is very slightly thinner and it rattles around if its not secured.
...or at least in my experience
Old May 7, 2009 | 02:38 PM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
SL600 / Avant Garde always gives a sleek modern look
