To update my grill on a 87 w124...
Mike
I'm in FL
zahkunst@hotmail.com
Style 1 - AVANTGARDE:
Style 2 - MHW:
http://www.mhw-gmbh.de/CarStyling/g...bd4fd5cca7f5d31
Style 3:
Style 4 - SL Look -Grill:
5- WALD
BILLET INNER GRILL
I don't have a pic for this grill on a car. If someone does please post a pic!
S600 INNER GRILL
You can do the 1994 1995 Hood/Grill conversion like in the picture below or buy a used hood/grill from a salvage yard.
Check out these links:
http://www.slaccessories.com/CatalogPage.php?Page=16
www.tuningzubehor.com
mike
QUOTE=zahkunst]hey dood I have the avantgarde grille pre '93 fitment that I'm actually not going to be using because I am looking to get another car...I never tried to install it but i do know it fits right into the factory grille frame although the top connector on a stock frame is not on it for some reason....if you want to buy it or ask questions about it feel free to email me about it....I am going to ebay it eventually anyway..
I'm in FL
zahkunst@hotmail.com[/QUOTE]
They look nice in a picture, but I think they are junk.
Black OEM looks great!
I'm going to be doing a mix and match to see what combo I like...
Having a Wald EX replica spoiler painted shell gray to match the cladding along with painting the bumper inserts.
Have a new OEM chrome grille surround and the old one will be painted signal red body color ala AMG.
One OEM grille insert will be painted black, the other shell gray.
I leave one set of strips chrome, paint the other red, gray, black whatever looks the best.
Will mix and match OEM shell and OEM inserts along with a S600 insert to see what I finally like !!!
DIY is the way to go !!!
I'm not planning anything drastic--actually I want as close to original as possible. However, the black on the insert is fading/peeling to light gray, and the chrome is completely gone from the 3 horizontal and 1 vertical trim strips on the insert.
I want to remove the insert (the chrome surround still looks OK), spray-paint the insert flat black, attach some new chrome strips off eBay for like $24 (unless you all know of a cheaper source) and reinstall the insert in the grille. I think what I am planning is identical to what Shin did above, and my desired end result is to have my grille look just like his.
Step-by-step instructions for an idiot would be most helpful...
First open your hood....
Remove the nut at the top center that holds the MB emblem on and also a screw in the center bottom of the grille shell.
Should be two? clips on each side that you push off.
Insert should come out.
The chrome strips will slide off of the insert.
