R134a kits locally?
I already swapped the shrader valve itself, so it must be that unit in its entirety...Is this something I can buy anywhere local?
Any other ideas to plug it basically? I saw this R134a "recharge valve" that I thought might work as it is supposed to plug onto any R134a system...I figured if I could just screw it on, that would solve the vacuum leak....but I got it home and its too big to fit on. Whats the deal with that too? Aren't all R134a systems the same? I am very new to A/C...so bare with me
1) I recharged my 260E .....
2) I saw a few bubbles from the shrader valve where you recharge it.....
3) I already swapped the shrader valve itself...
4) I saw this R134a "recharge valve" that I thought might work as it is supposed to plug onto any R134a system...but I got it home and its too big to fit on.
5) Aren't all R134a systems the same? I am very new to A/C...
To better understand your problem, I'd like to know the following:
1) What did you use to recharge your system?
2) By "shrader valve" do you mean the port where you connected your charging line?
3) What did you swap the "shrader valve" with? and How did you do it?
4) What "r134a recharge valve" are you referring to? The one in the cars refrigerant line or the one connected to the r134a can?
Inlet and outlet ports are suppose to be the same in any vehicle equipped with r134a. They are different in size with Freon12 system, unless the PO charged it with r134a without replacing the port.
Sorry for asking a lot of questions. But, I want to understand your problem so I could give you a correct suggestion/solution.
2. The little tiny valve that sits inside the charging line. So yes, I am looking to replace the Port seeing as the new shrader valve didn't stop it leaking.
3. Swapped it with the correct OEM shrader valve I got the stealership.
4. I found this valve that you can attach to the recharge line that punctures the can and then you open the valve and it flows through. I figured if I could just attach it and leave it that would seal it....if that makes sense? A cheap and easy fix. Not exactly pretty or perfect, but it should have worked if it had fit.
I appreciate the help!
Just to make things clear, we are talking about the port where you connect your charging line when you re-charged your system, right?
It is the cold line when the ac is on.
Well I guess I could use the thing I used to charge from -- but it was a device...so I'd have a long charging end hanging around. I guess it can work for now as long as I tie it up good...Cali is hot as heck right now and it sucks driving around w/o A/C.
So the correct name for that port is the check valve? Is that common to R12 and R134a or are they different?
Check the one your recently bought, it may be for the outlet port that's why it won't fit on the inlet port.
In California the law banning use of R12 refrigerant from vehicle took effect early 1996 (IIRC). So, vehicles after that year came equipped with R134a. Also, restrictions were placed over sales of R12 for use on vehicles that existing vehicle with R12 needing repairs had to be converted to 134a.
