I need a head: 1989 300te
My cam is worn on my 1989 300te. I will need to replace it. Aside from a new one (which I will also then need rockers= Big bucks), can I get a used head and just clean that sucker up? Where is a reliable place that I can oder a used head and be assured that the cam will be viewed by the seller before it's shipped? There must be smart, reliable salvage/ used part houses?
What about going to the junkyard and pulling a head? All the M103 heads are the same and you should be able to get a good idea with the valve cover off. I bet the whole head as one wouldn't cost you much at all.
1987 260E
I just had the same problem, cam wore down on #4 & 5 intake lobes. Replaced the head this weekend with a used improved head from a '90 300e 2.6 at the junkyard for about $100. Runs pretty nice now.
Other than a junkyard, let us know where you source your head...all data is helpful to us.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
Kevin
